Error integrating with interim result
Error integrating with interim result - Integral gives different result if a variable is calcukated (and not defined) - Сообщения
#1 Опубликовано: 23.07.2019 09:59:53
Stefan Weisskircher
Stefan Weisskircher
I have a simple integral calculation which contains a varable "n". If this variable is calculated in an earlier step, a wrong result is returned; the same calculation with a defined value for the variable (called "n2" in the example), the correct result appears. SMath Studio version 0.99, build 7030.
Is there a possibility to upload my sample file?
#2 Опубликовано: 23.07.2019 10:04:05
Arie
Arie
What version are you running?
I'm not seeing this issue on 7109.
Might help if you also posted the .sm file in question.
#3 Опубликовано: 23.07.2019 10:07:13
Stefan Weisskircher
Stefan Weisskircher
Hello alyles,
thanks for your answer! I have already edited my original post to add the version info.
i cannot find a button to upload my sample file... (still searching)
#4 Опубликовано: 23.07.2019 10:07:18
Arie
Arie
Sorry I missed this. To upload start writing a comment, click the following button....
then click add file first. Navigate to file and select. Then you must click start upload to upload it.
#5 Опубликовано: 23.07.2019 10:11:11
Stefan Weisskircher
Stefan Weisskircher
Thanks again, here we go:
Bug_Integral.sm (4,05 КиБ) скачан 1404 раз(а).
#6 Опубликовано: 23.07.2019 10:12:41
Arie
Arie
Are you concerned with the fractional result on the red?
If so right click on that section and change optimization to numeric. You'll get a numeric result.
#7 Опубликовано: 23.07.2019 10:16:05
Stefan Weisskircher
Stefan Weisskircher
Doesn't help, I still get "-18" in the left section (which isn't correct IMHO and still deiffers from the result on the right side (green))
#8 Опубликовано: 23.07.2019 10:20:00
Arie
Arie
Ok I just tried this in 7030 (latest stable) and can confirm I get the same results as you. This looks like a bug.
when I performed the same calculation in the newest beta version, the results seem correct.
#9 Опубликовано: 23.07.2019 10:20:00
Stefan Weisskircher
Stefan Weisskircher
Thanks a lot! So I don't have to search anymore!
#10 Опубликовано: 24.07.2019 11:58:21
Always plot the integrand for reluctant region.
Doctored SS 6179 ... seemingly same as SS7109
Bug_Integral [Doctored].sm (23 КиБ) скачан 1162 раз(а).
