Unit Conversion
Unit Conversion - Change from International System Units to other derived units - Сообщения
#1 Опубликовано: 24.04.2022 00:34:20
CBG
CBG
Hello
Does anyone know how to change the following units in the matrix shown below?:
from "kg/s" to "t/hr",
from " kg/{'m*'s^2}" to meters Water Column ("mH2O"),
"{'kg*'m^2}/{'s^3}" to Watts.("W")
Colebrook_SI_CBG.sm (29,41 КиБ) скачан 1290 раз(а).
Carlos
#2 Опубликовано: 24.04.2022 00:58:52
Hello
Possibly not with your original result matrix, if you shall use results later.
It can be shown in a table region or another pseudo result matrix.
Here is the table method.
Click to enlarge
#3 Опубликовано: 24.04.2022 01:46:38
Here is your matrix with pseudo units.
Not very elegant, but it is there.
Clickto enlarge
#4 Опубликовано: 24.04.2022 03:05:54
Hola Carlos. You can use matrix algebra in the unit placeholder. Here one solution.
Colebrook_SI_CBG.sm (24,74 КиБ) скачан 1322 раз(а).
#5 Опубликовано: 24.04.2022 11:21:48
from " kg/{'m*'s^2}" to meters Water Column ("mH2O",
Hola, Carlos
Moody as stand alone.
#6 Опубликовано: 24.04.2022 12:59:14
Hola, Carlos
Relation with what Carlos asked?
None, as usual.
#7 Опубликовано: 24.04.2022 17:39:01
CBG
CBG
Hello
Many thanks to Overlord for his suggestions and solution.
Muchas Gracias tambien a Alvaro por su solucion.
I also thank Jean.
Carlos
#8 Опубликовано: 24.04.2022 17:53:16
None, as usual.
Project is Colebrook, of which the core algo is Moody.
Read Alvaro to learn more.
#9 Опубликовано: 24.04.2022 18:08:40
Reading you in mathcad forums is also instructive.
https://www.eng-tips.com/viewthread.cfm?qid=335795
#10 Опубликовано: 02.05.2022 13:24:12
Ruben Sidranski
Ruben Sidranski
WOW, I feel old. I didn't even remember I was on that forum/website. Thanks for the memory...
#11 Опубликовано: 22.05.2022 09:36:36
Stevan
Stevan
How do I set my units so my answers are in the unit I want, at the moment the answer is being returned to Pa (Pascal) and I would prefer to have the answer in kPa(KiloPascal) or even kN/m^2.
I am also getting answers in N(Newtons) and would prefer to have them set to kN (Kilo Newton) rather.
#12 Опубликовано: 23.05.2022 14:17:43
Stevan
Stevan
That moment you realize you didn't save a copy of the problem :/ just redid it and realized I have a lot to learn about this program
Thanks for the welcome
Coversion Problem.sm (26,14 КиБ) скачан 1301 раз(а).
#13 Опубликовано: 23.05.2022 18:32:27
How do I set my units so my answers are in the unit I want?
Your attached document is fine. Jean's computer is broken.
About your question, there is a placeholder within results.
It will appear when you select result. It appears as a black square.
You can change your desired result units by altering it.
Here is a demonstration how you can do that.
#14 Опубликовано: 23.05.2022 20:53:08
Stevan
Stevan
I had a feeling it was going to be something so simple, this is brilliant, thanks!
