Cloud version & features
Cloud version & features - Сообщения
#21 Опубликовано: 28.04.2015 10:00:56
Hello, Radovan!
Is there any chance to fix this in order we could register under the same username, i.e the username we used for the Forum?
If you already registered for using http://smath.info/upload/ or http://smath.info/upload/extensions.aspx then you just need to log in. No registration required. Try to log in and you'll see your username in the top-right corner of SMath Studio in the Cloud page.
Sorry, but I can nor login neither register to both of these services under the user name "omorr". It sais it was already useed (by me, of course). I had to register under another username and to use another email address.
Never mind, I managed to login into the recent Cloud version (under the different username than "omorr" )
#22 Опубликовано: 29.04.2015 17:04:57
2 345 сообщений из 4 059 понравились пользователям.
Группа: Super Administrator
Fresh update:
History panel is implemented (see the button in the top-right corner under your login)! Now (if you logged in), you can see all worksheets ever created from your account. Creation date, date of the last change, file name and thumbnail is shown for every sheet (except empty documents - thumbnails are not generated for them).
Another improvement is a Properties dialog added under File menu - using this dialog you can change file name (new features will be added to this dialog in future).
Davide Carpi 29.04.2015 18:44:00, ioan92 30.04.2015 04:52:00, Radovan Omorjan 29.04.2015 18:04:00
#23 Опубликовано: 03.05.2015 18:39:50
The history panel is a very useful improvement! BTW I think there's no reason to keep in the cloud the empty files
Andrey Ivashov 04.05.2015 18:13:00
#24 Опубликовано: 04.05.2015 18:12:52
Davide, absolutely agree with you.
Couple of days ago I've updated cloud version so it don't display empty worksheets in history panel at all.
Thank you!
Radovan Omorjan 05.05.2015 13:29:00, Davide Carpi 04.05.2015 18:38:00
#25 Опубликовано: 02.06.2017 13:34:28
Hello. Glad to introduce new version of SMath Studio Cloud and it's awesome features:
It supports different languages (only English and Russian activated for now). Application interface, units of measurements, decimal/arguments separators, functions names, errors, equations descriptions and content text - everything is localized! Use language switcher in the upper right corner.
In English:
In Russian:
Drag'n'drop of Worksheets and image files implemented (Worksheets are opened in the separate tab, while images will be added directly at the cursor location).
Context menu is now supported for focused Regions.
Dynamic assistance is implemented for all applicable Regions (it is also localized based on the selected language).
About dialog contains date of the last update and version of the SMath Studio Core used on server-side (it will always correspond to the latest available SMath Studio version if nothing critical is found there).
I hope you'll enjoy new features!
Best regards, Andrey Ivashov.
6 пользователям понравился этот пост
Radovan Omorjan 02.06.2017 14:10:00, frapuano 02.06.2017 14:29:00, sergio 02.06.2017 14:46:00, Вячеслав Мезенцев 02.06.2017 14:50:00, Davide Carpi 02.06.2017 14:51:00, Fridel Selitsky 02.06.2017 15:53:00
#26 Опубликовано: 21.03.2018 10:48:30
Serge
Serge
Hi Andrey,
Your cloud version is a really interesting feature to share some calc apps.
I think that a version of your cloud environment could be advantageously deployed in companies looking for a web based calculus tool. Of course it would need to be deployed on a local server.
Do you think a local cloud deployment pack could be made available for such usage ?
Best Regards,
Serge
#27 Опубликовано: 21.03.2018 18:59:19
Hello, Serge.
It is impossible due to agreements I've signed.
Currently, SMath Studio in the Cloud can be located on smath.info domain only. This means I am able to deploy web-app on any server I want if it's IP is mapped to my domain.
Best regards!
#28 Опубликовано: 23.03.2018 04:26:23
Serge
Serge
Andrey,
Thanks for your feedback. But I do not understand precisely what you mean with IP mapping of the server to your domain (sorry I'm not an IT specialist). It's just to know if I have any chance in convincing my IT dept to do so.
Best regards,
Serge
#29 Опубликовано: 23.03.2018 12:52:29
Serge,
Literally answer is: no, it is impossible to install SMath Studio in the Cloud within your local network.
The only possible case is to find server (outside of your company intranet) which will be geographically close to you (in order to minimize network latency) and install SMath Studio in the Cloud there. This server must be available using smath.info domain (f.e. YOUR_COMPANY.smath.info/cloud or similar).
Davide Carpi 23.03.2018 13:05:00
#30 Опубликовано: 23.03.2018 13:06:04
Serge
Serge
Andrey, Davide,
Thanks for the details.
Best regards,
Serge
