Column sumation of a complex matrix
Column sumation of a complex matrix - I want to sum all numbers on a specific column - Сообщения
#1 Опубликовано: 15.10.2023 15:25:52
Tere Sergiu-Gheorghe
1 сообщений из 2 понравились пользователям.
Hello guys,
I have a matrix with system of values in it. I want to sum up all the column.
Could you help me with this?
sumcomplexcolumn.sm (9,96 КиБ) скачан 1191 раз(а).
#2 Опубликовано: 15.10.2023 17:33:50
Oscar Campo
Oscar Campo
It's necessary convert each system of your 5th column to a matrix by sys2mat() function, then you can stack each matrix from 5th column and do the summation:
sumcomplexcolumn SOLVED.sm (12,77 КиБ) скачан 1169 раз(а).
Oscar
#3 Опубликовано: 15.10.2023 18:01:59
ioan92
ioan92
180 сообщений из 120 понравились пользователям.
Hi Sergio,
Of course, Oscar’s proposal is a very interesting one
May I make a simple suggestion: avoid the use of “sys” data and replace it with a simple sum, as in my appended file.
Best Regards,
Ioan
If the column's sums are aasked, here is a solution for keeping the answer inside the box...:d
sumcomplexcolumn (1).sm (11,7 КиБ) скачан 1192 раз(а).
#4 Опубликовано: 15.10.2023 18:09:35
Oscar Campo
Oscar Campo
Hi Sergio,
Best Regards,
Ioan
Nice!, you think out of the box :d
#5 Опубликовано: 15.10.2023 20:32:04
Doctored version from construction.
sumcomplexcolumn.sm (9,96 КиБ) скачан 1214 раз(а).
#6 Опубликовано: 15.10.2023 20:41:06
Thank you very much guys for your answers!
I bought the paid version of smath also because this forum has such great users.
Oscar Campo 16.10.2023 22:26:00
