HVAC Constants (IP)
HVAC Constants (IP) - Derive HVAC Constants in SMath - Сообщения
#1 Опубликовано: 08.01.2021 22:24:21
Ruben Sidranski
Ruben Sidranski
Good evening,
Looking for suggestions to better improve the maths. I am working on the write up on the side on another Sheet.
I'm having an issue in when it comes to eliminating units, better yet, proving units cancel out. Suggestions on how to better derive and show the process is appreciated.
HVAC Constants.sm (55,22 КиБ) скачан 1150 раз(а).
Alvaro 09.01.2021 05:15:00
#2 Опубликовано: 09.01.2021 05:18:20
Good evening,
Hi. SMath convert all numbers to it rational approximation in symbolic outputs. Maybe you can use this trick: put Q*ΔT in units and use numeric evaluation:
#3 Опубликовано: 10.02.2021 13:22:13
Ruben Sidranski
Ruben Sidranski
Help with the highlighted please. How do I put the variables into Units? File is updated on my laptop to numeric evaluation.
#4 Опубликовано: 10.02.2021 14:20:26
The error message reads yellow not defined
#5 Опубликовано: 10.02.2021 15:00:17
Ruben Sidranski
Ruben Sidranski
And ALVARO had a way around it where his SNIPPET/PICTURE shows what I want
#6 Опубликовано: 10.02.2021 15:08:42
HVAC Constants.sm (62,47 КиБ) скачан 1179 раз(а).
Hi. Just write them: " Q*ΔT*'BTU/'hr " in the unit's placeholder.
I attach the file too.
sergio 10.02.2021 15:39:00, ElSid 10.02.2021 15:45:00
#7 Опубликовано: 10.02.2021 15:46:22
Ruben Sidranski
Ruben Sidranski
Got it. You force the solution (=) side to keep Q and ΔT as variables. I think I tried everything BUT that!
Revised file HVAC Constants.sm (62,98 КиБ) скачан 1128 раз(а).
