Most compact units for Vector and Matrix
Most compact units for Vector and Matrix - Easier to read with engineer units - Сообщения
#1 Опубликовано: 06.01.2022 08:40:51
babElec
babElec
1 сообщений из 5 понравились пользователям.
I read some post about units, but my problem occurs only for Vector / matrix.
If a declare a Matrix : P28V with three values (16V, 28V and 31.5V) and I want to display the result, the unit will be for each result : kg*m²/(A*s^3)
Units in matrix
Are there some restriction about it?
For each Matrix that I used, I have to specify each time the unit (like V, mA) instead of the bigger one
Another feature, I read a topic about it but without enough explanation. It could be very practical to have automatically the appropriate units factor (M,k, , m, µ, n) before the units.
Thank You, Emilien
#2 Опубликовано: 06.01.2022 10:01:50
kg*m²/(A*s^3)
What does that mean to the Electrician measuring 735 000 volts ?
A good way to get rid of those stupidities: make units silent
#3 Опубликовано: 06.01.2022 11:04:36
The Engineer style is what I used in my documents.
There is no much chance God will return °C from measured mV.
#4 Опубликовано: 06.01.2022 14:21:31
You can use the "unit placeholder" for display in the desired unit. Also can display several units for the same vector.
Yes. Or at least an ENG notation mode, like in the calculators, with scientific notation but with exponents multiples of three.
#5 Опубликовано: 06.01.2022 14:48:20
babElec
babElec
THank you for your help.
I understant I can change the unit manually to have the desired one.
But it not optimized especially for the vector, each time I have to changed the unit manually. If all the data on the vector have differents units, it take some times.
Have a nice day, Emilien
#6 Опубликовано: 06.01.2022 15:35:51
Off topic, Engineer style ... many solvers don't take units.
Cheers Emilien ... Jean
Inst_Colebrook Pipe Data.sm (71,45 КиБ) скачан 1404 раз(а).
#7 Опубликовано: 06.01.2022 16:37:12
FindRoot() can solve with units.
maple solve and maxima solve can solve units too if I remember correct.
You are just short of many more solvers.
That reminder was from Martin.
#8 Опубликовано: 06.01.2022 16:47:24
