Beta: SMath Studio 0.99.7632 (23 November 2020)
Beta: SMath Studio 0.99.7632 (23 November 2020) - Сообщения
#1 Опубликовано: 22.11.2020 19:59:11
Группа: Super Administrator
Изменения, входящие в версию 0.99.7632
Улучшения
  • Experimental support of new Document mode implemented;
  • Added ability to select Custom Region PlugIn which will be used in Document Mode;
  • Scaling mode is saved between sessions now;
  • The following auto scaling modes added: page width, content width, full page;
  • gf (Gram-force) unit added;
  • Picture Region automatically scale drag'n'droped image according to available page width;
  • Preview in SMath Viewer menu item added to Tools menu;
  • Added support for Regions with custom line breaks;
  • Support for page breaks added for Container Regions;
  • "Break on pages bounds" menu item added to Text Region (option turned on by default for new documents).
Исправления
  • Better support for broken Worksheet files implemented;
  • Hidden exceptions fixed in SMath Viewer applications;
  • Rendering of text improved (the same content looks more similar on screen and on print out);
  • Multi-threading issues fixed in MathRegion and TextRegion;
  • Disable/enable evaluation for Area Region when auto-evaluation disabled fixed.
Разное
  • DEV: Line breaks is supported now for custom Regions (IRegionWithLineBreaks interface);
  • DEV: Added possibility to extend SMath Studio with menu item in File, Edit, Tools or Help drop-down of main menu;
  • Code cleanup;
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_7632.Mono.tar.gz (1,42 МиБ) скачан 3363 раз(а).
SMathStudioDesktop.0_99_7632.Setup.msi (2,3 МиБ) скачан 7699 раз(а).
Denis Nikitin 23.11.2020 05:20:00, sergio 23.11.2020 06:00:00, Davide Carpi 23.11.2020 06:19:00, Igor Skarine 23.11.2020 21:00:00, IVR 27.11.2020 08:51:00
#2 Опубликовано: 22.11.2020 20:41:15
Information about Document mode can be found here: https://en.smath.com/forum/yaf_postst20002_Document-mode.aspx
See also:
  • New scaling modes:
  • Preview in SMath Viewer:
  • Line breaks:
#3 Опубликовано: 01.12.2020 17:19:45
Hi Andrey,
Starting since version 0.99.7610, the EFI plugin doesn't work on one of my PCs, but works fine on another one.
I tried to investigate the issue and found that it happens after I set 32-bit flag for using the plugin.
Both computers run the same latest version of Win10_x64.
After starting 32b-"patched" SmathStudio, it pops up hole bunch of messages like "bla-bla-bla.dll is not found".
If I clear the 32bit flag, Smath starts OK, but of course EFI doesn't work.
The same "patched" SmathStudio works fine on another computer and EFI works too.
Could you please advice how to fix this strange issue?
Best Regards,
Igor
Possibly this is related to how you installed SMath Studio. If you directly download it from the web, then security settings in Windows may prevent some dlls from execution. Don't ask me why the executable can run but some dlls can't.
In the majority of the cases this can be fixed by copying the files to some flash drive and then copy them back. This seems to remove some obscure "dangerous" flag.
My observation is that not every computer is affected by this, possibly depends on the windows build.
This created quite some confusion when I was faced with a lot of students failing to install SMath during an introductory course. I was close to suspecting something broken in my portable distribution (see link in the signature). Once the workaround was found, I placed a hint on the download site.
#4 Опубликовано: 02.12.2020 01:28:33
When the program starts a log file appears in the plugin installation folder. Please, show its contents. If there are several folders, then try deleting everything and reinstalling the plugin.
Igor Skarine 02.12.2020 11:08:00
#5 Опубликовано: 04.12.2020 16:56:14
Hi. Sorry if it's a silly question, but, from the post I read:
> Changes introduced in current build
> Improvements
What's "SMath Viewer"?
#6 Опубликовано: 04.12.2020 19:33:42
> Improvements
Hello.
Please look into the following thread for the details about SMath Viewer: https://en.smath.com/forum/yaf_postst1784_SMath-Viewer.aspx
Alvaro 04.12.2020 19:39:00
#7 Опубликовано: 04.12.2020 20:16:27
Oh, thanks. I forgot that this is the name for make executables files. I guess that isn't the best name for that! Usually "Viewer" means a version for read files but without buying the software. There are also another "modes". Mathcad have some other. For instance, the web application server, with a lot of examples from Valery Ochkov. This could be a good bussines area for SMath for distribute worksheets in an enterprise intranet.
I think that the viewer "mode" is more than an "application server", but without a web based interface. Matlab have those both modes too. For example, this is the "Matlab expo" from an old version.
This is yow it look for one example
Notice that this could be called like a "slide mode" for matlab, but make those slides requires programming skills.
Mathcad demo mode that I have it's old: it's for DOS. Here the starting msg saying that it is free for distribute, under certain conditions:
And here is how it looks:
This is the demo folder for mathcad for DOS.
DEMO.ZIP (300,65 КиБ) скачан 2498 раз(а).
#8 Опубликовано: 05.12.2020 16:58:16
SMath Viewer is a free tool with some limitations for commercial usage. And limitations will gone soon in one of next releases. Just had no time to update a plugin yet.
Alvaro 05.12.2020 17:16:00
