How can I use not a for but a while cycle?
How can I use not a for but a while cycle? - Messaggi
#1 Pubblicato: 09/02/2024 21:27:16
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
See please the attached file.Newton.sm (23,6 KiB) scaricato 1634 volta(e).
#2 Pubblicato: 09/02/2024 23:38:00
⚜ Kenny Lemens, P.E. ᵂᴵ
85 apprezzamenti in 181 post.
Greetings,
Instead of using for(3); you can use for(4):
for ▮, ▮, ▮
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
   k:=2*i
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
Valery Ochkov 10/02/2024 14:37:00
#3 Pubblicato: 10/02/2024 14:38:31
Valery Ochkov
Valery Ochkov
Thanks
But see "???" in the attach
Newton-for-1-2-3-4.sm (26,47 KiB) scaricato 1568 volta(e).
#4 Pubblicato: 10/02/2024 18:38:42
StvMath
StvMath
44 apprezzamenti e 1 disapprezzamenti in 76 post.
Here's a "while" version
Newton-for-1-2-3-4_b.sm (18,98 KiB) scaricato 1621 volta(e).
Valery Ochkov 10/02/2024 19:44:00
#5 Pubblicato: 11/02/2024 01:58:11
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52,75 KiB) scaricato 1493 volta(e).
Valery Ochkov 11/02/2024 02:13:00
#6 Pubblicato: 11/02/2024 02:53:28
Valery Ochkov
Valery Ochkov
Roots vs Newton
#7 Pubblicato: 11/02/2024 07:55:50
oots vs Newton
No interest vs the codes
#8 Pubblicato: 11/02/2024 13:41:06
Valery Ochkov
Valery Ochkov
Roots vs Newton
https://www.mdpi.com/2227-7390/10/19/3413
#9 Pubblicato: 11/02/2024 21:59:12
roots solves Matrix.
Worksheet33.sm (6,96 KiB) scaricato 1588 volta(e).
#10 Pubblicato: 13/02/2024 06:19:59
Gruppo: Moderator
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16,22 KiB) scaricato 1657 volta(e).
Alvaro 29/02/2024 12:13:00
