1 страниц (10 вхождений)
How can I use not a for but a while cycle? - Сообщения
See please the attached file.Newton.sm (23,6 КиБ) скачан 1628 раз(а).
Greetings,
Instead of using for(3); you can use for(4):
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
example:
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
for ▮, ▮, ▮
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
k:=2*i
k:=2*i
Valery Ochkov 10.02.2024 14:37:00
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52,75 КиБ) скачан 1490 раз(а).
Valery Ochkov 11.02.2024 02:13:00
Wroteoots vs Newton
No interest vs the codes
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16,22 КиБ) скачан 1653 раз(а).
Alvaro 29.02.2024 12:13:00
