1 pagine (20 elementi)
Beam calculation - Ber7 - Messaggi
https://smath.com/wiki/GetFile.aspx?File=Beam.rar
Oscar Campo 19/11/2011 23:33:00
https://smath.com/wiki/GetFile.aspx?File=Cantilever.rar
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks.
Ed
Ed
https://smath.com/wiki/GetFile.aspx?File=Cantileverzip.zip
https://smath.com/wiki/GetFile.aspx?File=Beamzip.zip
Ed
Ber7,
Your animations and drawings always amaze me. Thanks.
Ed
https://smath.com/wiki/GetFile.aspx?File=Contin%5d.zip
https://smath.com/wiki/GetFile.aspx?File=ElastFound.zip
Hello.
This is very nice. I am civil ingenieer & I will use it. Thanks.
However it is dangerous to use the function x>Lf.
I found it out in my own beam programming.
When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down.
And for the following input it does not!
It seems to me, the function x>Lf does not work correctly each time.
Regards Olik
SMath files: beam 3 & 4.zip
Regards Olik
Olik, try to change x>Lf to eval(x>Lf).
Thank you, kmihaylovich, the file is corrected.
Regards,Ber7
Regards,Ber7
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
Regards.
Regards.
Thanks to all. The eval function seems to be a good way.
And if You fix this little bug, it will be the best.
Regards, Olik
Regards, Olik
Graphics with shading
(http://en.smath.info/forum/resource.ashx?a=1691)
AnimBeam2.sm (38,63 KiB) scaricato 1662 volta(e).
4 utenti hanno apprezzato questo post
Вячеслав Мезенцев 11/06/2013 12:00:00, ioan92 11/06/2013 05:58:00, IVR 11/06/2013 12:39:00, Davide Carpi 12/06/2013 19:18:00
Cantilever-new edition
https://smath.com/wiki/GetFile.aspx?File=CantileverENExe.rar
CantileverEN.smz (18,82 KiB) scaricato 1831 volta(e).
Analysis of statically indeterminate beam. Supported cantilever.
Beam fixed at the one end supported an the other
https://smath.com/wiki/GetFile.aspx?File=Konsol%2bopora.rar
Konsol+opora.smz (134,15 KiB) scaricato 1814 volta(e).
