3D Plot Region
3D Plot Region - CreateMesh() and 3D Plot - Messaggi
#1 Pubblicato: 28/04/2013 20:38:19
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
3D Plot Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Regions: 3D Plot.
Functions: CreateMesh().
3DPlotRegion_screen1.png 3D Plot. CreateMesh. Example 3.png 3D Plot. CreateMesh. Example 1.png 3D Plot. CreateMesh. Example 2.png 3D Plot. CreateMesh. Example 4.png
3D Plot. CreateMesh. Examples.zip (190,33 KiB) scaricato 1659 volta(e).
5 utenti hanno apprezzato questo post
zoom 17/01/2016 17:06:00, Infinity 29/04/2013 03:12:00, Oscar Campo 29/04/2013 10:27:00, Davide Carpi 29/04/2013 11:57:00, Radovan Omorjan 29/04/2013 02:10:00
#2 Pubblicato: 03/05/2013 15:12:32
Gruppo: Moderator
Looks promising!
In particular I like the right-handedness of the plot.
Issues:
- IsVisible attributes of axesstyle and gridstyle are not responsive.
- strange behaviour if z limits are exceeded by the z-surface. I guess that the surface should be trimmed by the bounding box. Otherwise the axes have to be included in the hidden line algorithm. For now you seem to assume that they are always in the background.
- definition of a function is mandatory. No pure xy-expressions.
#3 Pubblicato: 03/05/2013 16:51:14
Gruppo: Moderator
Yes, I know about all these problems. They are based on the library that I used. I'm working on that too.
Let's imagine the xy-expression: 1 + x*y + 3*(x-y)+ sin(t0) -> 1 + x[1]*x[2] + 3*(x[1]-x[2])+ sin(t0) or 1 + x[2]*x[1] + 3*(x[2]-x[1])+ sin(t0) ?
Unlike X-Y Plot we have two independent variables. How do I know their order (x,y) or (y,x)? That's why it is not implemented in Mathcad too. I don't want use only x and y variables for that purpose.
#4 Pubblicato: 03/05/2013 17:09:44
Gruppo: Moderator
It seems that you can delete the function name "f" from the placeholder and to put something else. It will keep the previous function and not complaining.
#5 Pubblicato: 03/05/2013 17:40:00
Gruppo: Moderator
OK, clearyl I have to accept and respect your preferences, but I would not mind x and y being used as dummy variables just like in the built in 3D graphics region. That may, of course, be limited to cases, where there is no pure function name given.
Assigning the x-axis to the first and the y-axis to the second argument of the plot function prevents the user from plotting f(y,x) instead of f(x,y). If you want to be free to avoid the look of x and y in the placeholder, then you still can assign x and y to other names. You even could get the names as smart defaults for axis labels.
The freedom in variable choice in the xy-plot is obtained at the price of having to keep these variables unassigned above that plot. Even Davide's Clear won't help (I tried that).
#6 Pubblicato: 03/05/2013 17:52:31
Gruppo: Moderator
I can do this:
1. If you enter a function f(2) then I think it equal to f(x, y)
2. If you enter a function f(1) then I think it equal to f(x[1],x[2]), where x - vector ([x,y]).
3. If you enter a simple expression and it has one undefined variable, then I think it is a vector ([x,y]).
#7 Pubblicato: 03/05/2013 18:21:20
Gruppo: Moderator
Never mind! I shall cope...
#8 Pubblicato: 03/05/2013 19:49:36
kilele
kilele
134 apprezzamenti in 397 post.
uni, i don't know if you could take advantage of this code:
http://www.codeproject.com/Articles/42174/High-performance-WPF-3D-Chart
#9 Pubblicato: 03/05/2013 19:56:34
Gruppo: Moderator
Yes, it's interesting, I added to my bookmarks. I have an account on codeproject.
There is another similar things: Plot 3D surfaces.
#10 Pubblicato: 04/05/2013 04:51:20
kilele
kilele
BTW, the author of the book you mentioned in the xyplot thread, has another book about WPF
"Practical WPF Charts and Graphics"
#11 Pubblicato: 07/05/2013 17:44:23
Gruppo: Moderator
Updated. Function CreateMesh() moved from the Plot3D plugin. Do not use it any more.
#12 Pubblicato: 07/05/2013 18:07:09
Gruppo: Moderator
Thanks for the update. I installed the updated version and removed Plot3D.
now the 3DPlotRegion plugin shows up twice in the plugin manager, see attached screenshot.
#13 Pubblicato: 07/05/2013 18:46:03
Gruppo: Moderator
Don't worry, this is normal. Andrey will correct it.
#14 Pubblicato: 09/06/2013 08:00:54
kilele
kilele
I mentioned this resource in another thread.
These are some c# wrappers for VTK:
http://www.vtk.org/Wiki/VTK/CSharp/ActiViz.NET
http://vtkdotnet.sourceforge.net/
#15 Pubblicato: 09/06/2013 08:01:26
kilele
kilele
I mentioned this resource in another thread, VTK.
These are some c# wrappers for VTK :
http://sourceforge.net/projects/vtknetexamples/
#16 Pubblicato: 18/06/2013 09:02:12
Gruppo: Moderator
I am using the plugin from the extension manager.
Seems that I can now save the regions, but user settings aren't saved (see attached sheet, where the default settings are not really appropriate).
Is that a local problem or known bug?
Uni, are you going to continue this branch of plotting or do you focus on other ways?
NelderMead.sm (29,83 KiB) scaricato 2164 volta(e).
#17 Pubblicato: 01/02/2014 15:37:28
Gruppo: Moderator
CreateMesh() is useful for 2D plots as well...
Radovan Omorjan 02/02/2014 02:47:00, Вячеслав Мезенцев 02/02/2014 04:22:00, ruddy 02/10/2025 13:25:26
#18 Pubblicato: 02/02/2014 06:54:16
Gruppo: Moderator
In the previous version, the expression to plot had to be an explicitly defined function. This condition is now relaxed thanks to Davide's FunctionsExtensions plugin. Using the at(expr,var) function, you can substitute values for undefined variables in arbitrary expressions, thus you can use these expressions as if they were functions.
Uni, if you would make CreateMesh() flexible in that it can handle 2- and 3-element vectors, then poking out the submatrix in the 2D case would not be required any more.
ruddy 02/10/2025 18:00:01
#19 Pubblicato: 04/03/2014 13:58:30
Gruppo: Moderator
The current version (0.1.5161.27307) of the 3DPlot plugin interferes with the clipboard. If pasting any expression from the clipboard to the canvas, I get a 3DPlot region instead. There used to be a similar problem with Hyperlink and Conditionally formatted labels, Davide managed to handle this.
#20 Pubblicato: 23/03/2014 10:12:58
Henrique
Henrique
1 apprezzamenti in 17 post.
Is it possible to use augment(u;v;f) on 3DPlot plugin, like we use on a X-Y Plot plugin? (u;v;f are vectors).
rod_spring.sm (32,11 KiB) scaricato 2116 volta(e).
