solve & roots with units
solve & roots with units - Messaggi
#1 Pubblicato: 03/06/2023 08:48:30
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
I can it solve in Mathcad - see please mcdx and pdf files
I try solve it (heat transfer) in SMath - see sm file
Help please
File non trovato.File non trovato.File non trovato.
#2 Pubblicato: 03/06/2023 15:37:44
Gruppo: Moderator
Help please
SMath symbolic solving of integration is not capable as Mathcad.
Thus integrals can't be used with numeric solvers.
However, you can use a little trick to solve them.
Using maple or maxima plugins is the key.
Here is your problem solved with various ways, roots() and Findroot().
solvewithunits.sm (23,4 KiB) scaricato 1426 volta(e).
Valery Ochkov 03/06/2023 15:53:00, sergio 04/06/2023 13:03:00, NDTM Amarasekera 04/06/2023 03:15:00
#3 Pubblicato: 04/06/2023 02:18:41
Hi. The attached have an al_nleqsol wrapper for a Mathcad block with units, that can accept SMath's integrals too.
Click to enlarge
Kerimov-Cvetkov-Velichko-1-7 - nSol.sm (17,97 KiB) scaricato 1458 volta(e).
sergio 04/06/2023 13:03:00, Valery Ochkov 04/06/2023 02:22:00
#4 Pubblicato: 04/06/2023 10:00:56
Gruppo: Moderator
Actually, you don't need to find Tc2 first hand.
Findroot() can solve with all three equations at once.
All important is the order of unknowns.
Valery Ochkov 04/06/2023 12:03:00, sergio 04/06/2023 13:48:00
#5 Pubblicato: 05/06/2023 00:08:21
Gruppo: Moderator
Here is a paper-friendly version.
Also check how variable guess points are assigned.
Valery Ochkov 05/06/2023 02:23:00
#6 Pubblicato: 05/06/2023 02:24:02
Valery Ochkov
Valery Ochkov
Thanks!
Send please the sm file.
#7 Pubblicato: 05/06/2023 11:08:24
Hello Valery,
In some application(s), you can associate FindRoot with epsilon.
Solve Diophantine Chemical Balance epsilon.sm (106,1 KiB) scaricato 1489 volta(e).
Valery Ochkov 05/06/2023 11:26:00
#8 Pubblicato: 05/06/2023 17:39:04
Gruppo: Moderator
Thanks!
solvewithunits.sm (14,13 KiB) scaricato 1416 volta(e).
#9 Pubblicato: 26/06/2023 02:33:01
netsonicyxf
netsonicyxf
2 apprezzamenti in 79 post.
Please help, why can't find root for this simple equation?
root.sm (20,2 KiB) scaricato 1394 volta(e).
#10 Pubblicato: 26/06/2023 05:54:06
Gruppo: Moderator
Because there aren't unknows
#11 Pubblicato: 26/06/2023 08:45:01
Please help,
why can't find root for this simple equation ?
roots solves wrt scalar function(s)
In this example, both functions are scalar wrt 'x'.
Try ... roots[(sin(x)-Gamma(x),x,1]
'x not defined' ... Gamma(x) is not scalar wrt 'x'
Few more numerical functions are not scalar
erf(x), erf(x,n) ... erfc(x), erfc(x,n) ...
#12 Pubblicato: 26/06/2023 08:55:02
In that case and similar ones,
RootSecant algorithm will spits out 15 decimals, instantaneous.
#13 Pubblicato: 26/06/2023 10:06:59
netsonicyxf
netsonicyxf
Thanks Davide.
Now I put "N" as unknown in the Eq. But it can't be solved either.
root.sm (19,41 KiB) scaricato 1361 volta(e).
#14 Pubblicato: 26/06/2023 10:58:58
Gruppo: Moderator
You have to play a little with the precision, especially if there are units involved; in this case, seems that 10^-3 mm is a stable target (10^-2 works too, but in some case it returns the guess value, meaning that is "close enough" for the algorithm - you can see in the plot that 0kN to 200kN is in +0.02/-0.02mm range)
root_r1.sm (24,03 KiB) scaricato 1430 volta(e).
netsonicyxf 26/06/2023 12:18:00
