1 pagine (7 elementi)
Function as variable for another function - Is it possible to use function as variable for function if in this functon is if statement.. - Messaggi
is it possible to add function as argument to another function if in that function is if statement?
I guess that you have an unit issue, instead to ask "x=1" try with "x=1*'m".
CitazioneI guess that you have an unit issue, instead to ask "x=1" try with "x=1*'m".
no i tried with out any units.. as far as i can tell its if there is if in the function i cant use it as argument for another function even if it plots perfect as i imagine..
so i played around even further:
it seems that: i can make boolean operations with x and i can use if if x is not evaluated.. but if in if statement there is x then it shows that x is not defined.? is this bug?
Integral 0Discrete Cumulative 10 styles.sm (179,98 KiB) scaricato 1162 volta(e).
