1 pagine (7 elementi)
Fit Methods Essentials - Fit Methods Essentials - Messaggi
Global fitting session [0 .. 14]
1. al_nleqsolve point select equalities
valid for noisy data via user piecewise linear.
2. Levenberg-Marquardt: generally valid [fails Frechet]
3. Cholesky matrix solver ... solves all, faster
model function(s) parameters, linfit components,
remarkable linfitCheby, polyorder, direct discrete data.
............................ rational fraction.
EMERITUS => Conjugate gradient Minimize(init,iter)
Genfit_0 Read First.sm (32,45 KiB) scaricato 1354 volta(e).
Genfit_2 L-M AUTOMATED PieceWise-Global Reflexive Copy.sm (69,25 KiB) scaricato 1391 volta(e).
Genfit_4 linfit HyperRobust [Ge Crystal] Copy.sm (82,26 KiB) scaricato 1167 volta(e).
Genfit_7 GenfitMatrix Copy Master ToolBox Copy.sm (62,69 KiB) scaricato 1379 volta(e).
Genfit_9 Chemist.sm (34,68 KiB) scaricato 1313 volta(e).
Genfit_5 LinfitCheby Order [HadCRU] Copy.sm (120,98 KiB) scaricato 1182 volta(e).
Genfit_8 Poly 000 Order System.sm (20,15 KiB) scaricato 1323 volta(e).
Genfit_3 L-M AUTOMATED PieceWise Carlos Original Copy.sm (130,72 KiB) scaricato 1366 volta(e).
Genfit_6 Rational Auto-init ITER [LongRange type_J] Copy.sm (123,72 KiB) scaricato 1121 volta(e).
Genfit_11 Pharmacokinetics LMSA ... [Carlos 2020].sm (50,36 KiB) scaricato 1176 volta(e).
Genfit_10 Frechet.sm (96,8 KiB) scaricato 1347 volta(e).
Genfit_13 NON-Linear.sm (37,25 KiB) scaricato 1382 volta(e).
Genfit_1 L-M AUTOMATED Carlos 20200115 [Exampless] Copy.sm (265,69 KiB) scaricato 1135 volta(e).
Genfit_14 AUTOMATED al_nleqsolve.sm (83,36 KiB) scaricato 1361 volta(e).
Genfit_12 Pharmacokinetics LM ... [Carlos 2018].sm (55,45 KiB) scaricato 1141 volta(e).
NDTM Amarasekera 28/01/2020 04:28:00
1 ... please: recycle Genfit_14
replace by high pro refreshed/augmented.
2. Add Genfit_15 [Thiele Procedure]
Genfit_15 Thiele Procedure [Carlos-Jean].sm (76,66 KiB) scaricato 1170 volta(e).
Genfit_14 AUTOMATED al_nleqsolve.sm (85,48 KiB) scaricato 1392 volta(e).
... add this Meritas to your tool box.
Genfit_16 MERITAS al_nleqsolve.sm (29,95 KiB) scaricato 1353 volta(e).
Hola Jean
This is my best setting for "Genfit_10 Frenchet" in SS-6179
with LM using 6 data, since an out of memory error occurs using all data.
SS-7251 solves it without any problem with all the data.
Genfit_10 Frenchet LMSA ..SS6179.sm (56 KiB) scaricato 1321 volta(e).
Genfit_10 Frenchet LMSA ..SS7251.sm (45,17 KiB) scaricato 1327 volta(e).
Carlos
Carlos
Hola Jean
Genfit_16 MERITAS resolved with LMSA in SS-6179 and SS-7251.
Genfit_16 MERITAS LMSA_SS6179.sm (53,02 KiB) scaricato 1364 volta(e).
Genfit_16 MERITAS LMSA_SS7251.sm (52,9 KiB) scaricato 1375 volta(e).
Carlos
Carlos
WroteHola Jean
This is my best setting for "Genfit_10 Frechet" in SS-6179
Thanks Carlos, got 9 points superb fit !
Next will check MERITAS ...
Genfit_10 Frenchet LMSA ..SS6179.sm (55,67 KiB) scaricato 1353 volta(e).
WroteHola Jean
Thanks Grand Doctor Carlos ...
So, my native SS 6179 suffers numerical issue
that SS 7251 cures in your SS 6179 ... Ah !
LMSA in native SS 6179 takes much higher TOL [typical 0.0001/0.00001]
F.B. Hildebrand wrote "fitting is an art ..."
Can't be more right !
