SMath units
SMath units - Wrong units - Messaggi
#1 Pubblicato: 24/11/2023 05:13:51
Oichi
Oichi
4 apprezzamenti in 35 post.
For a simple harmonic oscillator with mass "m" (kg) and spring constant "k" (N/m), the angular frequency of oscillation is sqrt(k/m).
If we used the SI units, the angular frequency unit should be (rad/s) but when I use units in SMath it gives the answer in Hz..
So, is there a way that I can correct the units for an answer? Thanks in advance
#2 Pubblicato: 24/11/2023 17:38:44
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
You can change units in this way...
Oscar
Oichi 25/11/2023 00:36:00
#3 Pubblicato: 25/11/2023 00:13:01
... Unit User Hz ... rad_s.sm (2,82 KiB) scaricato 1406 volta(e).
Oichi 25/11/2023 00:40:00
#4 Pubblicato: 25/11/2023 00:40:02
Oichi
Oichi
Thank you all ^^
Oscar Campo 25/11/2023 03:57:00
