1 pagine (7 elementi)
at function in SMath - Messaggi
Hello!
What is the advantage of at function in SMath ?
Appreciate if any useful example is provided.
Cheers !
Cheers !
Hi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's f /. x -> a notation, and perhaps there you can see how those programs use it and get a better idea of what it might be useful for. I also remember that den derive, which did not have a function like at, could be used instead ... take the limit: lim f for x -> a
WroteHi Amarasekera, a pleasure to greet you. I'm sure others in this forum will be able to give very good examples, I would just like to add that the 'at' function is more or less similar to the 'eval' in maple, although it also has a 'subs' function, and even another one like 'algsubs', or Mathematica's [b]f /. x -
Hi Alvaro, thank you very much for your kind sentiments and valuable clarifications.
Handbook page for at() and Solve(). at() is a convenient alternative for Assign(), which creates assignments based on equations (as returned by Solve, ODE2 or Fit())
at.sm (22,23 KiB) scaricato 1376 volta(e).
_Solve.sm (33,17 KiB) scaricato 1399 volta(e).
![2023-06-07 20_12_17-SMath Solver - [_Solve.sm_].png](/it-IT/files/Download/TsxkoZ/2023-06-07-20_12_17-SMath-Solver---[_Solve.sm_].png)
Electron function added Φ(x,y)
This function has no symbolic solution.
It plots X_Y but for QuickPlot, you need solving.
Solve at(2), at(3).sm (47,5 KiB) scaricato 1411 volta(e).
Thank you all for the clarifications and examples
