Basic Graphics
Basic Graphics - The augment function maybe not working on Linux - Messaggi
#1 Pubblicato: 29/03/2023 14:41:21
Javier Ochoa
Javier Ochoa
3 apprezzamenti in 26 post.
I installed Smath Studio from the AUR repository, I am using Arch and the installation went fine.
I am reading the document GraficasBasicas2012.pdf, which I downloaded from the Wiki Tutorials.
The problem is that the function augment(1,2,3) works different under Linux, and I cannot figure out how to make a simple graphic as the one in the adjointed file.
graficos_prueba.sm (9,46 KiB) scaricato 1636 volta(e).
Maybe someone could help me, regards.
#2 Pubblicato: 29/03/2023 15:59:11
Javier Ochoa
Javier Ochoa
In the Tools->Options Section I could change the semicolon <;> and now I use the comma (,) as separator. Now I can use the function augment with comma (,) but the graphic function is still not working.
I wonder whether someone can give me a hint.
#3 Pubblicato: 30/03/2023 08:09:11
... fast, perfect meshing 'x'.
#4 Pubblicato: 30/03/2023 10:21:48
Javier Ochoa
Javier Ochoa
Hi Jean,
Tank you for the post, he problem was solved using the pallete. I will mark as solved.
#5 Pubblicato: 30/03/2023 11:34:39
Hi Jean,
Tank you for the post, he problem was solved using the palette.
NO Javier, NOT solved.
Your 'x' is improperly meshed.
#6 Pubblicato: 30/03/2023 12:16:30
Javier Ochoa
Javier Ochoa
Hi Jean,
I can reproduce your example without any problem, I cannot understand where the parameters H,N and L are defined. Also, you defined a function xd and used to evaluate x. Why I cannot use range?.
I suppose that is there an useful explanation for this, which I am curious about it. Maybe, you can give me some hint?
#7 Pubblicato: 30/03/2023 13:09:12
Hi Jean,
[L,H,N] are defined in x:= xd(L,H,N)
Why I cannot use range ?.
If you use range, 'x' will start -pi
but will never exactly terminate +pi
unless N in range is 15 decimals ... totally foolish.
Your graph does not terminate +pi.
xd discretizer will populate exactly any 'N' ± pi.
#8 Pubblicato: 30/03/2023 15:28:21
... complete algo style, one of my preferred.
Javier.sm (10,69 KiB) scaricato 1622 volta(e).
#9 Pubblicato: 30/03/2023 16:22:54
Javier Ochoa
Javier Ochoa
Hi Jean,
I am greatly surprised with your answer.
I will take care of this lesson in future calculations.
Thanks in advance,
#10 Pubblicato: 30/03/2023 21:49:26
Gruppo: Moderator
If your purpose is plotting a range, this is the way.
This is most suitable for your type of functions.
No mumbo jumbo, no algorithm, no unnecessary coding.
Only pure simple if block.
graficos_prueba1.sm (11,05 KiB) scaricato 1637 volta(e).
sergio 31/03/2023 10:20:00
#11 Pubblicato: 31/03/2023 09:40:31
Javier Ochoa
Javier Ochoa
Hi Overlord,
I very appreciate your thoughts, the graphics looks pretty good.
Kind regards
#12 Pubblicato: 31/03/2023 10:55:57
Hi Jean,
Thanks in advance,
The all thing is to complete a project, mostly export.
See the missing regions ...
Please, don't hesitate ... Jean.
Javier More.sm (9,5 KiB) scaricato 1672 volta(e).
#13 Pubblicato: 31/03/2023 11:05:02
Javier Ochoa
Javier Ochoa
Hi Jean,
This file is showing the origin of some missing parameters, like H,L,N, thank you for this worksheet.
I have a BSc in chemical engineering and a PhD in Industrial Chemistry, I also work in a biotechnology institute since 2003.
Maybe, this is why I was asking so many questions.
Kind regards,
#14 Pubblicato: 31/03/2023 20:27:42
You are not used yet to Smath algorithmic construction
Eager to assist your ChemEng projects.
#15 Pubblicato: 01/04/2023 10:20:34
To fully understand the command line algorithmic construction,
revisit this 4 examples document. Cheers ... Jean
Solve(f,q,x0,x1,TOL).sm (54,65 KiB) scaricato 1608 volta(e).
