1 pagine (9 elementi)
Disable specific unit - How to disable not used unit - Messaggi
Hi, in my calculations I often use kJ/kg (and derivative) units (enthalpy, specific heat).
SMath always presents result in Gy and I have always manually to redefine it.
Is there any possibility to disable Gy unit which is useless for my tasks?
I tried to assign 'Gy := 0 to disable this unit but it does not work.
WroteIs there any possibility to disable Gy unit which is useless for my tasks?
Work sheet would help.
Unitless solves all problems.
Knowing in advance the unit of result, define it user style
kJ/kg ... Smath style kJ_kg:=1
copy "kJ_kg", paste in the empty place holder of result.
WroteHi, in my calculations I often use kJ/kg (and derivative) units (enthalpy, specific heat).
When you re-defined Gy, did you use the ' infront of Gy (e.g. 'Gy? This makes it the same font/etc.
I work in IP units and need to re-define everything in the results. Part of the quirks of working in SMath
btw, the default unit depends on optimization setting.
symbolic evaluation gives bare SI base units.
numeric evaluation gives some derived unit, which might or might not be appropriate for the given case.
I have to agree with m227. Can we request this as a feature as Gy is hardly applicable in most cases.
WroteI have to agree with m227. Can we request this as a feature as Gy is hardly applicable in most cases.
Hi. This is a workaround. Edit the file Units.xml under the SMath/entries/ folder, disabling the entries for the unit Gy:
Then you can get, for example, the enthalpy from Coolprops plugin in J/kg by default:
frapuano 09/11/2018 06:54:00
![2018-04-27 12_35_35-SMath Studio - [steamprop.sm_].png](/it-IT/files/Download/sRrz2Q/2018-04-27-12_35_35-SMath-Studio---[steamprop.sm_].png)
