1 pagine (14 elementi)
Jean Giraud!!! Help with the spline line - Messaggi
Hello!
Based on your examples, you love math. I and my friend Andrey (not Ivashov) are engaged in development of the program ZCAD with open source code. I am an amateur programmer (this is my hobby), I write rarely when I have time. In the ZCAD project I am 2 years old, at first I wrote narrowly focused things to facilitate the work, now I want to develop the interface and the convenience of work for everyone. At the moment the program can draw a spline line in 3D, by reference points. But you can not create a line in the program, it is created by user vertices. We can not devote so much time to math, so that having custom vertices get the spline line reference points. For us it is a very complex mathematics.
You recently posted an example of "Spline De Boor", I did not find this topic so I created a new one. In this example, you draw a spline line in 2D using reference points.
Actually, please. Help, please, solve the mathematical problem: Having the user vertices, got the spline point reference points in 3D. Also in the program Smath.
Below is the files of your website "Spline De Boor" and my file.
Original user points (XYZuser)
reference points of the spline line (XYZreferpt)
Thank you in advance!
PS Sorry that the question is not on the program smath
Presumably, I understand what you are after ...
... Create a 3D system of vertices, you need 3 matrices.
We have it in Mathcad from Russia. Even if it is possible
to code in Smath, no way to plot because Smath does not plot
stacked matrices [it does not plot matrices at all].
Smath plots matrices as image but not as 3D.
The Mathcad 11 program subdivides by 2 each step from
the Catmul-Clark B_Spline. On the other hand, Mathcad
is on ORIGIN [0], it adds difficulty to code Smath.
In short: I can attempt to code wrt Smath ORIGIN [1].
If your base 3D system does not plot 3 stacked matrices... zap !
Chers, Jean
![Spline Catmul-Clark [3].bmp](/it-IT/files/Download/Z7hcqF/Spline-Catmul-Clark-[3].bmp)
Chers, Jean
Hello!
I have poorly explained and you misunderstood me. Our spline is NURBS. https://en.wikipedia.org/wiki/Non-uniform_rational_B-spline . We are interested only in the spline line which consists of 3 coordinates.
There are points that lie on the line, I call them user points
There are points that lie outside the line, I call them reference points
In your example, you point the reference points to draw a spline.
Below I bring an animated gif, so you understand what I'm talking about.
We would like to understand how from points lying on the line, get points outside the line, and vice versa.
It is not yet clear how to get an Knot value and a degree of the spline curve for constructing a spline. At the moment the program uses that knot value and the degree that we read from a file created in another CAD
Here, also shows the construction of the spline, and there is a switch between points lying on the line and points outside the line. Pay attention to the degree that is being changed. https://en.wikipedia.org/wiki/File:Spline01.gif
Sorry for the incorrect mathematical terminology!
All those things are most confusing. I couldn't download the animated GIF
from the Wikipedia link ... Why ? Essentially, what you are after is a way
to pass a spline through a set of control points to any adjustable curvature.
In short: a way to reproduce what CAD system do under the hood.
The first answer is easy in Smath from Hermite polyline. I just have a simple
example. There is no limit but will take some time to construct a good demo.
This feature is most essential in robotics to allow the path be convex and
adjustable curvature. Will work on that.
... Cheers, Jean
Spline De Boor [Loop].sm (72,29 KiB) scaricato 1006 volta(e).
Spline De Casteljau SVG Companion.sm (100,35 KiB) scaricato 1253 volta(e).
Spline Hermite Polyline.sm (35,14 KiB) scaricato 1272 volta(e).
Spline Bezier_DeBoor.sm (40,11 KiB) scaricato 1216 volta(e).
Spline Bezier_Bernstein.sm (55,55 KiB) scaricato 1249 volta(e).
... Cheers, Jean
I looked at the example of Hermite's polyline, the resulting spline is not similar to the spline obtained in the CAD system. I send the superimposed spline of the CAD system to the graph of the Hermite polyline.
Bézier Cubic 4 cntrl points looks more like the desired spline.
Spline used in CAD systems non-uniform rational B-spline (NURBS).
I spread an animated gif from Wikipedia, it will explain very well how the spline is drawn in the CAD system and how it is edited.
.WroteI looked at the example of Hermite's polyline, the resulting spline is not similar to the spline obtained in the CAD system. I send the superimposed spline of the CAD system to the graph of the Hermite polyline.
The CAD example [image] is probably Bézier parametric.
They just perform differently, especially if the end
points aren't duplicated. In other applications,
Hermite has much better smoothing properties than
DeBoor, Bézier .
Spline Hermite Polyline.sm (39,13 KiB) scaricato 1201 volta(e).
We can not choose any other type of spline. Between the CAD systems should be a single approach to the construction and display of the spline. We are limited to the dxf specification:
https://www.autodesk.com/techpubs/autocad/acad2000/dxf/spline_dxf_06.htm
Here is another link to the presentation of splines. as I understand, the 38.40 page shows the NURBS spline and the text says about the meaning of roots and degree
https://www.cs.drexel.edu/~david/Classes/CS430/Lectures/L-09_BSplines_NURBS.pdf
WroteWe can not choose any other type of spline. Between the CAD systems should be a single approach to the construction and display of the spline. We are limited to the dxf specification:
If you can't choose splines that work for Engineers, what's the point of the exercise.
When AutoDesk formed [~ 1985], it is just after meeting Pierre Bézier, which was sponsored by
Sergei Natanovich Bernstein: 1880 .. 1968
Alma Mater: Université de Paris
I believe AutoCad is based on Bernstein.
I will have more for you on that.
Cheers, Jean
WroteI will have more for you on that.
The UFO that was done for Russian Friends [mid 2000]
Spline Bernstein OVNI.sm (21,37 KiB) scaricato 1254 volta(e).
... please, revisit these 6 documents.
The Gaussian spline is very useful at times.
It was the main tool to help fit Carbon 12 α.
There is lot more past this 1rst step. Final gorgeous fit
that Matlab muffed so badly with their "Splinesmooth" !
Spline Esplina [AI2000].sm (21,9 KiB) scaricato 1035 volta(e).
Spline Esplina [DeBoor].sm (33,21 KiB) scaricato 1023 volta(e).
Spline Esplina [Hermite].sm (35,09 KiB) scaricato 1041 volta(e).
Spline Bernstein OVNI.sm (25,4 KiB) scaricato 1305 volta(e).
Spline Gaussian.sm (45,15 KiB) scaricato 1266 volta(e).
Spline Hermite Polyline.sm (54,42 KiB) scaricato 1304 volta(e).
Hi!
Sorry that I did not answer for a long time, these days were very busy.
As part of our program, we can add many kinds of spline lines, but we need a spline that supports all the other KADs.
I studied the spline lines sent by you. below the picture. I also added the information that AutoCAD adds to the file for the correct display of the spline line description
black dashed line - this is because the points outside the spline line are located
pink - this is the spline line obtained by auto cadence
File non trovato.File non trovato.File non trovato.File non trovato.File non trovato.
... from what your system shows, I guess the spline is Bézier polyline.
This type of multipoint is executed from the DeCasteljau algorithm,
more numerically stable. We can't reproduce it scalar algo style Mathcad 8.
I may still have the Bézier polyline demo in what's left from Mathcad 11.
Will be back later on.
Cheers, Jean
Cheers, Jean
... that confirms your CAD system is Bézier-DeCasteljau.
Spline Polyline Hermite_Bezier.sm (49,36 KiB) scaricato 1269 volta(e).
