1 pagine (5 elementi)
Edit a chart - How to insert numbered points in a graph - Messaggi
Hello to all.
I have traced these three functions, that depend on time, on the graph.
How can I insert numbered points, superimposed on the traced functions, so that the same numbering corresponds to the same instant of time?
To be clear, I should do something like the following figure …
This is the .sm file: CALCOLI TESI manovra.sm (69,86 KiB) scaricato 1149 volta(e).
thanks in advance for the help
using some good tips posted by Jean, you could do this:
CALCOLITESImanovra_s.sm (78,32 KiB) scaricato 1144 volta(e).
I preferred to refer to actual times and not to anonymous labels; however you can use the same methodology more easily
Ale16595 22/01/2020 08:32:00
WroteI have traced these three functions
Can you trace these functions from the previously doctored document.
Why jump ship [new thread] from suite to suite ?
WroteThis is the .sm file:
What's next past the DE ?
CALCOLI TESI manovra ... What Next.sm (70,75 KiB) scaricato 1200 volta(e).
