EXCEL (2003+) I/O with recalculation and export to PNG
EXCEL (2003+) I/O with recalculation and export to PNG - Uses EXCEL PIA (2003+) to import/export data to and from XLS/XLSX files - Messaggi
#101 Pubblicato: 20/09/2021 14:18:08
Ricardo_Herrera
Ricardo_Herrera
1 apprezzamenti in 8 post.
Citazione
XLSXupdate.txt (1,81 KiB) scaricato 1367 volta(e).
first it is a great surprise is to be able to greet his person.
Thank you very much for your time. and by Smath Studio. Thank you very much for what you teach and what you do.
Rikardo21
#102 Pubblicato: 20/09/2021 16:14:43
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Please try to update the plugin. Your version is from last year and is out of date.
#103 Pubblicato: 20/09/2021 16:48:37
Ricardo_Herrera
Ricardo_Herrera
XLSXupdate.txt (1,85 KiB) scaricato 1406 volta(e).
Update plugin, but error persists.
Keep holding
Rikardo21
#104 Pubblicato: 20/09/2021 19:19:45
Gruppo: Moderator
This problem appears due to the presence of old keys in the registry, which will contain the wrong path to Excel. Try to search in Google for a solution to your problem using the error text from the log file:
Excel HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED)
#105 Pubblicato: 21/09/2021 11:29:09
João Felipe Seráfico Melo
7 apprezzamenti in 62 post.
Ricardo, I updated the plugin and made a Quick Repair in my Office 365, restarted the pc and now it works perfectly.
The issue is some bug in Office register.
Thank you for your compliments, Ricardo! Glad to see my videos are helping!
#106 Pubblicato: 21/09/2021 12:37:50
Ricardo_Herrera
Ricardo_Herrera
Thank you very much I have reinstalled office and now it works.
thanks for everyone's help.
A hug from a distance.
to all.
Rikardo21
João Felipe Seráfico Melo 21/09/2021 14:48:00
#107 Pubblicato: 01/11/2021 08:46:47
Hi! I'm having trouble sending String variables to Excel.
For instance, ". - / ! ? ;" turns into \002E\\0020\\002D\\0020\\002F\\0020\\0021\\0020\\003F\\0020\\003B\ in Excel.
I'm using most recent SMath and Excel I/O versions.
#108 Pubblicato: 01/11/2021 10:05:32
Ricardo_Herrera
Ricardo_Herrera
Hello, good morning, could I send a screenshot to see the error that generates a hug from a distance
Rikardo21
#109 Pubblicato: 10/11/2021 12:26:03
oscar mauricio
oscar mauricio
1 apprezzamenti in 10 post.
Hi, I have the same problem as Ricardo, any recommendations to solve it?
Mostra spoiler
#110 Pubblicato: 11/11/2021 05:35:29
Gruppo: Moderator
SMath Studio compatibility
Plugin updated.
Changes:
- excel_in(): text encode issue fixed.
João Felipe Seráfico Melo 11/11/2021 08:48:00, oscar mauricio 11/11/2021 08:49:00
#111 Pubblicato: 11/11/2021 08:57:18
oscar mauricio
oscar mauricio
Thank you very much, fixed with update
#112 Pubblicato: 03/07/2022 04:18:14
Gruppo: Moderator
Plugin updated.
Changes:
- added support for environment variables;
- refactored.
Alvaro 03/07/2022 05:03:00
#113 Pubblicato: 03/07/2022 05:04:57
Plugin updated. ...
Hi Viacheslav. An example about what does that mean? Thanks.
#114 Pubblicato: 03/07/2022 06:10:06
Gruppo: Moderator
You can use operating system environment variables in the file path.
4 utenti hanno apprezzato questo post
NDTM Amarasekera 03/07/2022 08:00:00, churichuro 03/07/2022 12:59:00, Alvaro 03/07/2022 15:51:00, oscar mauricio 07/07/2022 11:37:00
#115 Pubblicato: 07/07/2022 11:54:58
oscar mauricio
oscar mauricio
Hello thanks for the plugin, I found a problem in the excel_In() command. I present it in the image, I hope it can be resolved in future versions.
#116 Pubblicato: 08/07/2022 04:45:19
Gruppo: Moderator
Plugin updated. Please try.
Changes:
- ToCell(): Globals.Excel.DecimalSeparator replaced by the CultureInfo.GetCultureInfo( "en-EN" ).NumberFormat.NumberDecimalSeparator;
- ToCell(): Double.Parse() fixed;
- part of the book "Excel 2002 VBA Programmer's Reference" added (Chapter 22. International Issues).
Click to enlarge
oscar mauricio 08/07/2022 16:00:00
#117 Pubblicato: 08/07/2022 07:01:35
Gruppo: Moderator
It is possible to simplify the interface. I can add a new feature. You can suggest your own version for a new feature.
#118 Pubblicato: 09/07/2022 06:43:56
Gruppo: Moderator
In a future release I will remove functions from ExcelIOCom to XLSXupdate. One function and one operand will be added.
File non trovato. File non trovato.
churichuro 09/07/2022 11:09:00, sergio 09/07/2022 11:20:00
#119 Pubblicato: 09/07/2022 12:41:31
Gruppo: Moderator
SMath Studio compatibility Examples
Changes:
- excel operand and excel() function added;
- readCell() and writeCell() moved from the ExcelIOCom plugin;
- examples added;
- refactored.
sergio 11/07/2022 05:47:00
#120 Pubblicato: 12/07/2022 03:40:45
Gruppo: Moderator
There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable:
excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML"
Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as:
- create books, add and delete sheets;
- accessing named ranges;
I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable.
oscar mauricio 15/07/2022 21:52:00
