Sqrt of a Matrix
Sqrt of a Matrix - PKlijn - Messaggi
#1 Pubblicato: 17/02/2013 04:52:32
PKlijn
PKlijn
0 apprezzamenti in 4 post.
I get the following error: "Matrix must be square" when taking the SQRT of a single column Matrix.
Is there some way to do this calculation?
#2 Pubblicato: 17/02/2013 05:38:14
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
One of the ways
Ek.sm (4 KiB) scaricato 1459 volta(e).
#3 Pubblicato: 17/02/2013 06:40:09
Gruppo: Moderator
You may consider using lists (AKA "systems" ). If the input values are obtained as matrix, then the function sys2mat from the CustomFunctions
Plugin may help.
#4 Pubblicato: 02/03/2013 11:23:37
PKlijn
PKlijn
Thank you, that works!
