Questions of solve function
Questions of solve function - Messaggi
#1 Pubblicato: 30/08/2024 08:11:47
soomoon
soomoon
1 apprezzamenti in 42 post.
he first formula calculated well.
The second formula did not calculate.
The result is "The stack is empty."
What is the problem?
#2 Pubblicato: 30/08/2024 09:18:59
Gruppo: Moderator
Either clear R or use a different variable name, R.1 for example.
Because you defined R at upper calculation, it confuses solvers.
