"Else" statement not appearing when I choose "if" from the programming pallete
"Else" statement not appearing when I choose "if" from the programming pallete - Problem using the if function from the programming pallete - Messaggi
#1 Pubblicato: 06/08/2022 12:59:16
James Mazon
James Mazon
0 apprezzamenti in 2 post.
I´m having problems with the if function on the programming pallete. When I choose "if" from the pallete it just shows two lines, there is no else anymore like on the image in the attachment. If I recall correctly the else statement used to automatically appear when you choose the "if" function from the pallete. Could someone help me understand what´s happening?
Mostra spoiler
#2 Pubblicato: 06/08/2022 14:03:26
127 apprezzamenti in 342 post.
First of all, check in Tools-Option-->Interface-->Arguments separators which setting you set up. They are possible "," "." ";".
Suppose it is ";".
In the placeholder digit once ";" to get Else or ";;" to get Elseif
#3 Pubblicato: 07/08/2022 12:12:44
James Mazon
James Mazon
Thank you! It worked
