Maple in SMATH - exponential curve fitting - Messaggi
File non trovato.
If not available, is there another similar regression fit function available?
Sorry about that. Update to sm file.
I am really struggling. It shouldn't be this hard.
This version of Maple 6 regression fit also does not work.
Maybe someone could give me examples of the five input arguments to the SMATH Fit(5) function as noted in the figure.
File non trovato.
As always, any help is appreciated. I really want to get away from Mathcad 15 because there is no longer any support.
with(linalg):with(inttrans):with(plots):with(stats):
Unfortunately, the Maple syntax is difficult to replicate in a document, so the ability to use the symbol engine is limited. I'll see if I can somehow use this solution with vectors from the document. Now I recommend using alternative solutions, which I hope will be offered soon.
What about the built-in Fit(5) function question?
This is what I am trying to achieve, but it defeats my purpose of getting away from Mathcad 15.
File non trovato.
Surly, there is a simple way to fit data with various functions in SMATH, but maybe not.
CLIMATE CHANGE.sm (19,28 KiB) scaricato 1593 volta(e).
About maple, as far I know, in the version 6 the equation to fit must be linear in the unknown parameters, as it don't have the uppercase 'Fit' package, but the old 'fit' one.
File non trovato.
My copy shows both of the plugins are available.
WroteIf not available,
is there another similar regression fit function available ?
Under the hood, your model is very reflexive. Thus not easy to fit.
... not easy to fit means various coefficients fit as well.
Differently, Cholesky polynomial fits as well, not reflexive.
Matter of preference.
Climate change is BS. Earth entropy is increasing till much colder.
Global warming [HadCRU] proves the decrease °C since ~ 2010.
Page2 Climate.sm (59,43 KiB) scaricato 1448 volta(e).
Inst_HadCRUt4.sm (267,2 KiB) scaricato 1341 volta(e).
File non trovato.
File non trovato.
Since I don't have MAXIMA, why do they show up as available?
I assume that means I must write my own since nothing offered so far gives a good fit like the Mathcad exponential fit.
Thanks for all your responses.
WroteSo, I have come to the conclusion that there are no built-in curve fitting routines in SMATH
That's right, Smath has no fitting plugin. However, we miss nothing.
miss nothing: Explain ...
Smath fitting techniques is a HUGE collection of advanced utilities.
By far more capable than MCD 11 unless they have implemented many more than Given/Minerr.
Please confirm you can download from the forum after disabling firewall(s).
Visit Samples ... LMSA Genfit attached few days ago.
I think you can use the Least Squares algorithm to fit the data.
CLIMATE CHANGE WORKING_CBG.sm (35,53 KiB) scaricato 1417 volta(e).
Carlos
Nothing yet, indicates it will be logistic asymptotic,
may be returning a Gaussian or crippled Gaussian.
The last part of the data set is noisy but has a trend.
WroteIt is possible to use this function, but it is difficult. To do this, you need to include the stats package in the with.inс file. By default, not all packages are included in the plugin and you must manually specify the required ones in the plugin folder (bin\with.inc):
Dear Uni I tried to duplicate your example after adding with(stats) to the plugin\bin\with.inc Unfortunately I seem to do something wrong. Could you assist me? Thanks in advance. I have added my attemptMapleFitTest.sm (3,75 KiB) scaricato 1332 volta(e).
1. fit linterp(vx,vy,x) but you don't have an export
2. fit Cholesky and export the fitted function.
Jean.
WroteSo, I have come to the conclusion that there are no built-in curve fitting routines in SMATH that will allow me to do an exponential fit like I do in Mathcad 15. ....
Hi Reg. The solution proposed at the post #4 in the file { CLIMATE CHANGE.sm (19,28 KiB) scaricato 1593 volta(e). } only uses an standard SMath plugin, for al_nleqsolve .
WroteI assume that means I must write my own since nothing offered so far gives a good fit like the Mathcad exponential fit.
In this graph, the solutions of SMath, Maxima and Mathcad are compared. SMath's solution seems as valid to me as Mathcad's.
Mahcad exponential fit is essentially based on LM resident code.
You can do same in Smath from Genfit techniques or Carlos LM.
All MCD fits done in the Mathsoft Collaboratory have been done in Smath.
Smath Genfit compendium is lot more immense.
Jean.
You have my file. If what you say is true, please post an example of an exponential fit to my data.
Thanks
