Fourier transform
Fourier transform - Mathcad Fourier transform doesn't work in SMath - Messaggi
#1 Pubblicato: 14/05/2026 16:19:57
Caro
Caro
1 apprezzamenti in 13 post.
Dear all,
I have a Mathcad Document about Fourier transform that I want to translate into SMath.
I already dowloaded the FFTPack plugin. I used the same functions from the Mathcad document which doesn't work in SMath.
I tried a bit but nothing is working. The error message says "The argument must be a scalar."
I attached screenshots from my SMath document and the original Mathcad document.
Does anyone have an idea or a helpful tip?
Thanks in advance
#2 Pubblicato: 14/05/2026 16:26:36
Caro
Caro
fft_spalt_test.sm (5,42 KiB) scaricato 521 volta(e).
#3 Pubblicato: 14/05/2026 18:55:58
127 apprezzamenti in 342 post.
try to construct the vector like this
Mostra spoiler
Caro 15/05/2026 07:01:47
#4 Pubblicato: 15/05/2026 07:07:59
Caro
Caro
Thank you! That worked and the error message is gone.
I'm still having trouble plotting the graph. The graph is not being displayed but there isn't any error message.
Did I overlook something? Does the rfft() function work different in SMath than in Mathcad?
Thanks in advance
#5 Pubblicato: 15/05/2026 07:57:42
Check if it can help you. The graph has the correct shape but the values are different.fft_spalt_test(sergio).sm (10,62 KiB) scaricato 522 volta(e).
Caro 15/05/2026 16:30:00
#6 Pubblicato: 15/05/2026 16:32:47
Caro
Caro
Thank you Sergio!
I'm going to try around with your file a bit more. But having the correct shape is already very helpful and good enough.
