Table Region PlugIn
Table Region PlugIn - Showing calculated values in caption or footnote - Messaggi
#1 Pubblicato: 29/01/2020 07:42:47
MBe
MBe
2 apprezzamenti in 21 post.
The Table region PlugIn is very useful (thanks Davide!) and nice, but I wonder if there is any way to show a calculated value in between other text in the caption (or footnote) field.
I see that there are special keys (%T, %S, %R etc.) to show some particular numbers in the caption, it would be interesting and useful to have, let's say, %V(varname) to show the value of a variable of the sheet.
Does anyone know a workaround or maybe this could be a future additional feature?
Thanks
Marco
#2 Pubblicato: 29/01/2020 09:19:06
Marco: not sure what you are looking for ?
Table Region [Project].sm (9,76 KiB) scaricato 1123 volta(e).
Table Region Carlos.sm (17,52 KiB) scaricato 1281 volta(e).
Table Region.sm (49,83 KiB) scaricato 1317 volta(e).
Levenberg_Marquardt_Code_CBG Model.sm (70,93 KiB) scaricato 1295 volta(e).
#3 Pubblicato: 29/01/2020 11:05:32
MBe
MBe
Jean, thanks for your help, your examples always have interesting hints.
However, what I would like to do is something like this below:
I would like to show a variable value in place of "xxxx" in the caption of the above table.
I have not found any way to do that and probably it is not possible, for the actual version of this plug-in.
Any suggestion welcome.
Thanks
Marco
#4 Pubblicato: 29/01/2020 12:22:10
... as live variable probably not possible.
If you say and tabulate the calculated values are normalized
at some speed xxx RPM then write it as such
All data normalized @ 3600 RPM
#5 Pubblicato: 29/01/2020 14:00:52
Gruppo: Moderator
You could just place a formatted label region over the caption . This is a bit weird but it works. Use the context menu to switch off input and border.
label.sm (4,57 KiB) scaricato 1268 volta(e).
In newer SMath versions, you can also use a standard text region with an embedded formula, where you can suppress input display and even specify a unit.
