Xlsx Import/Export plugin
Xlsx Import/Export plugin - share data between SMath Studio and XLSX spreadsheets - Messaggi
#1 Pubblicato: 10/06/2013 03:49:00
Gruppo: Moderator
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Here there is a plugin to share data between SMath and XLSX Spreadsheets (*.xlsx, *.xlsm).
Plugin UI languages: English Deutsch Italiano Русский Español
PLEASE REPORT IN THIS TOPIC ANY ISSUE.
  • requirements: SMath Studio 0.96.4909 or later, .Net Framework 3.5 (Windows) / Latest Mono distributive (Linux);
  • installation: download the plugin from the gallery;
  • documentation: XlsxImportExport_docs.7z (38,79 KiB) scaricato 2419 volta(e).;
  • languages: if you want to have a new UI language look into the documentation's Language folder.
Attached below OLD documentation for SMath Studio prior to 0.97.5346 (0.96.4909 <= SS < 0.97.5346)
XlsxImportExport_docs.7z (37,4 KiB) scaricato 2138 volta(e).
10 utenti hanno apprezzato questo post
Radovan Omorjan 10/06/2013 03:59:00, ioan92 10/06/2013 04:16:00, Вячеслав Мезенцев 10/06/2013 06:40:00, Serg 10/06/2013 07:08:00, Andrey Ivashov 10/06/2013 15:11:00, IVR 10/06/2013 15:32:00, zoom 17/01/2016 17:15:00, justhumm 06/12/2016 20:37:00, subseapark 10/01/2018 20:03:00, Igor K 01/07/2025 11:00:30
#2 Pubblicato: 10/06/2013 05:07:53
Gruppo: Moderator
thank you for the feedback
best regards,
Davide
#3 Pubblicato: 10/06/2013 06:45:09
genf
genf
6 apprezzamenti in 72 post.
How to use this plugin - did not quite understand. Thank you.
#4 Pubblicato: 10/06/2013 06:50:31
Gruppo: Moderator
Examples added to the first post (XlsxImportExport_docs.7z - nothing changes in the usage from those contained in the previous Data Exchange plugin)
Attached here a pdf to show the expected output.
regards,
w3b5urf3r
Xlsx Import_Export examples.pdf (62,56 KiB) scaricato 3140 volta(e).
#5 Pubblicato: 10/06/2013 07:03:52
Gruppo: Moderator
All plugin functions are explained in the function reference part of the handbook (see signature). It is in german, but the examples should be self documenting (most of them in fact taken from Davide's examples)
Serg 10/06/2013 07:21:00
#6 Pubblicato: 02/02/2014 23:52:57
Ernesto
Ernesto
13 apprezzamenti in 74 post.
I tried this plugin out, since importing and exporting to excel would be extremely useful.
However when I try to import a cell with a function referencing another cell, the cell reference is imported (eg: A5*G4), instead of the value of the cell. Is there any way around this?
Also, is it possible to export to an existing excel file, without overwriting it? I tried exporting to an existing file, and everything in the file gets erased, except for the newly exported data.
Thanks,
Ernesto.
#7 Pubblicato: 03/02/2014 13:56:49
Gruppo: Moderator
I need to see the ClosedXML API references...
About cell's references if I remember correctly there are some limitations (not all the functions are supported and not all the references, f.e. between different sheets) but I can check if something can be made...
For both the things, I'll see what I can do
#8 Pubblicato: 06/04/2014 09:49:33
Ryan Freund
Ryan Freund
20 apprezzamenti in 339 post.
In the example file it is stated
Citazione
import a single cell
(file in the same folder of this sheet; use a relative/absolute path otherwise)
Does this mean if the file is in the same folder as SMath?
It appears that the program looks where the Smath.exe file is stored is that correct?
Thanks
EDIT:
I wanted to use the folder where the calulcation page and the excel sheet was stored. Therefore I should first set CurrentDirectory(DocumentDirectory(""))
#9 Pubblicato: 06/04/2014 10:48:17
Gruppo: Moderator
Citazione
The "base" path is the path of the worksheet, if available (existing worksheet) otherwise is the user "Documents" folder.
The archive in the first post contains some import/export examples.
BTW the path of the executable has no much interest (in most of the cases the user don't know where it is or needs administration privileges to write inside it)
Best regards,
Davide
#10 Pubblicato: 18/05/2014 11:45:37
Gruppo: Moderator
Is the Excel import meant to be Viewer-safe? I get the attached error message if I try to run a viewer application with excel read. With ods-format the situation is similar.
#11 Pubblicato: 18/05/2014 18:12:19
Gruppo: Moderator
To be honest, I've never tried these plugins in SMath Viewer; seems that the external assemblies are not embedded in the Viewer.
As secondary thing reading the ClosedXML/Ionic.Zip licenses I suppose that any Viewer executable shall contains the relative copyright notice, and this actually is not possible (if this is not made by you manually)...
Martin Kraska 19/05/2014 14:45:00
#12 Pubblicato: 19/05/2014 14:49:19
Gruppo: Moderator
I try to setup a data browser for use by my colleagues, therefore any hints on how to do viewer-safe data import of spreadsheets are welcome. Perhaps this could be done within excel, but I am not comfortable with it and just use the opportunity to do some SMath testing.
#13 Pubblicato: 19/05/2014 18:07:46
Gruppo: Moderator
Nice idea...
Added in the BTS as SV-146 and SV-147
Best regards,
Davide
#14 Pubblicato: 05/08/2014 11:56:26
msiseminger
msiseminger
1 apprezzamenti in 1 post.
Davide,
The issue with "DocumentFormat.OpenXml.dll" not found when you create and run an .exe can be resolved by removing the reference to the .dll from the "References" section in your extention solution. You do not call this .dll anywhere in the extension so it is not needed. When I do this, I no longer get the missing .dll error.
The .exe still does not pull in the Excel spreadsheets I want with the missing .dll error fixed. I did do further investigation and the .exe program can not handle even a simple mat() function by itself with no other references. This lead me to believe that the .exe program is at issue and not your extension.
Mike
Davide Carpi 05/08/2014 14:05:00
#15 Pubblicato: 07/03/2015 10:05:02
Gruppo: Moderator
PLUGIN UPDATED
- ImportData.XLSX now get results where cells references other cells;
- fixed export on SMath Viewer;
#16 Pubblicato: 11/03/2015 15:26:49
Alexander O. Melnik
Alexander O. Melnik
127 apprezzamenti in 498 post.
Gruppo: Moderator
I figured this conversation is best to be continued here
COM plugins are a unexplored field for me. My first idea is to have something like a Calculate.MSExcel("file") / Calculate.LOCalc("file") functions; I don't know if this is possible for the whole document, anyway should be possible for a range Calculate.XYZ("file","cells").
Base documentation:
- for excel: How to: Run Excel Calculations Programmatically
- for LO: SDK 4.3: Common Language Infrastructure (CLI) examples
Is it possible to run visual basic script from your plugin? I have come up with (pieced together from numerous online sources) a .vbs file that will update (in background) all the XLSX files in the directory it is run from (it will actually run a background EXCEL process that can be tasked to do anything excel can). If this or similar could be incorporated in your plugin I can see following happening:
1. Modify "input" xlsx workbook using your data exchange plugin
2. Run .vbs script that will recalculate/save all workbooks linked to input work book (I wonder if it is possible to somehow start the sript from within Smath)
3. Export cell range from desired workbook
I am sure with .vbs there is a way to perform all input - calculations - output strictly in memory, so no files need to be saved unless desired. I am not sure, however, if it is something that can be used by a Smath Studio plugin.
SpreadSheet IOxlsx.7z (11,9 KiB) scaricato 1033 volta(e).
#17 Pubblicato: 25/06/2015 15:39:07
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5581
- import data: fixed bug when quotation mark (") is used in a cell, f.e. for inches measurements. Now this character is converted in the "Double Prime" character (″) [many thanks to Don Bollard for pointing out this bug];
- import data: importData.XLSX(3) now accepts a range of cells as third argument (f.e. "A3:B12");
#18 Pubblicato: 20/01/2016 13:32:54
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5737
  • importData.XLSX() can access files opened by other processes (only saved data);
ioan92 20/01/2016 14:08:00
#19 Pubblicato: 17/04/2016 07:43:28
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- added exportData.XLSX(4)* [extends exportData.XLSX(2)];
- added exportData.XLSX(5)* [extends exportData.XLSX(3)];
- importData.XLSX(...): fixes in path processing;
* How they works:
- If the file doesn't exists, a new file is created;
- If the sheet in the workbook doesn't exists, a new sheet is created;
- If the sheet exists in the workbook, data in the target cells will be overwritten; use these functions with caution if your output may have a different size at each run;
#20 Pubblicato: 17/04/2016 14:44:14
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Does this or any other "excel" plugin work with "ods" extensions? I am on Libre office on both Windows and Linux at home. I could not get to work.
