Using solve or maple.solve for Array
Using solve or maple.solve for Array - Messaggi
#1 Pubblicato: 17/11/2020 04:57:44
usamakhan
usamakhan
7 apprezzamenti in 97 post.
I want to using solve function for a simple arithmetic equation. But one of the value is an array so I must have array of answers. I am unable to achieve this using solve & maple.solve
As the last resort I had to solve the equation separately which is both boring & not dynamic. The equation has units...
Page1.sm (184,19 KiB) scaricato 1407 volta(e).
#2 Pubblicato: 17/11/2020 05:31:26
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
#3 Pubblicato: 17/11/2020 07:14:29
usamakhan
usamakhan
Thanks for the solution. Can you please explain why we need to vectorize (above arrow) the last statement?
Secondly I cannot add units to x in the function developed st_mass? My version is 0.99 (6671)
#4 Pubblicato: 17/11/2020 07:20:34
Gruppo: Moderator
If the function uses a scalar and you substitute a vector of values, then you need to either use a loop over the elements of the vector, or the vectorization operator.
Try to multiply x by 1 and replace 1 with units.
And I think that the maple() function is not needed here, an ordinary solve() should handle it.
#5 Pubblicato: 17/11/2020 08:23:15
usamakhan
usamakhan
Per my experience maple.solve handles units far better... However still I am not able to reproduce your results.
Sheet is attached, may be my version is old?
Page1.sm (174,42 KiB) scaricato 1448 volta(e).
#6 Pubblicato: 17/11/2020 08:29:19
Gruppo: Moderator
Keep in mind that the function maple() doesn't know anything about units at all. The function uses a special trick to ignore them in its work.
Try now
Page1 (uni).sm (175,19 KiB) scaricato 1383 volta(e).
Page1 (uni).pdf (380,33 KiB) scaricato 912 volta(e).
#7 Pubblicato: 17/11/2020 09:51:32
usamakhan
usamakhan
Mostra spoiler
Ok I made a typo fault. Everything OK now THNX
#8 Pubblicato: 17/11/2020 12:31:50
Here is Engineer style ... no need for Maple, just native Smath
Attached SS 6179 ... some volunteer to make it unit kg/s
Ioncube Otherwise.sm (20,16 KiB) scaricato 1213 volta(e).
#9 Pubblicato: 18/11/2020 00:47:29
Hi. I guess that the problem is that kw just like "kw" both in lowercase isn't an unit, but it is kW. To know the name of an unit you have the coup icon for insert one in the toolbar.
In the attached using kW instead kw, maple don't needs units manipulation, but SMath's roots needs.
Page1 (uni).pdf (413,26 KiB) scaricato 881 volta(e).
Page1 (uni).sm (177,25 KiB) scaricato 1427 volta(e).
#10 Pubblicato: 18/11/2020 09:17:56
... forget units, reconciliate as you wish in the solve bloc & Table
Ioncube Otherwise.sm (28,65 KiB) scaricato 1186 volta(e).
