3D-Scatter Plot
3D-Scatter Plot - How can I plot it - Messaggi
#1 Pubblicato: 05/05/2023 06:29:56
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
How can I plot 3-D diagram? So for example.
See please the SMath attach!
GTU-Ro-T.sm (383,51 KiB) scaricato 1482 volta(e).
#2 Pubblicato: 05/05/2023 08:32:19
1. Arrays dimension do not match.
2. Once doctored, maybe Maxima.
#3 Pubblicato: 05/05/2023 09:25:47
... a bit doctored.
GTU-Ro-T.sm (393,15 KiB) scaricato 1448 volta(e).
#4 Pubblicato: 05/05/2023 12:11:50
Gruppo: Moderator
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1).
GTU-Ro-T_Kr.sm (395,9 KiB) scaricato 1436 volta(e).
#5 Pubblicato: 05/05/2023 15:06:56
Dustin Reynolds
Dustin Reynolds
0 apprezzamenti in 1 post.
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap.
ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning
from all of the work on plug-ins etc...
hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad.
enjoy the clip..i may have smoked too much at that the time i made it.
In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses?
Funny Orbits 3.zip (3,61 MiB) scaricato 513 volta(e).
#6 Pubblicato: 05/05/2023 16:29:48
Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it.
Click to enlarge
GTU-Ro-T.sm (397,19 KiB) scaricato 1448 volta(e).
#7 Pubblicato: 05/05/2023 17:16:54
... differently by doing what's wanted.
3D Plot.sm (61,83 KiB) scaricato 1395 volta(e).
3D Axes System XYZ User Explorer.sm (52,17 KiB) scaricato 1463 volta(e).
3D Axes System Parametric Explorer.sm (21,02 KiB) scaricato 1411 volta(e).
3D Solid cut by Surface.sm (72,29 KiB) scaricato 1440 volta(e).
#8 Pubblicato: 05/05/2023 21:04:08
...project 2D on 3D
Analemma [Project_Anim].sm (33,25 KiB) scaricato 1188 volta(e).
Analemma PROJECTION.sm (81,08 KiB) scaricato 1420 volta(e).
