3D-Scatter Plot
3D-Scatter Plot - How can I plot it - Сообщения
#1 Опубликовано: 05.05.2023 06:29:56
Valery Ochkov
Valery Ochkov
67 сообщений из 708 понравились пользователям.
How can I plot 3-D diagram? So for example.
See please the SMath attach!
GTU-Ro-T.sm (383,51 КиБ) скачан 1442 раз(а).
#2 Опубликовано: 05.05.2023 08:32:19
1. Arrays dimension do not match.
2. Once doctored, maybe Maxima.
#3 Опубликовано: 05.05.2023 09:25:47
... a bit doctored.
GTU-Ro-T.sm (393,15 КиБ) скачан 1410 раз(а).
#4 Опубликовано: 05.05.2023 12:11:50
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1).
GTU-Ro-T_Kr.sm (395,9 КиБ) скачан 1390 раз(а).
#5 Опубликовано: 05.05.2023 15:06:56
Dustin Reynolds
Dustin Reynolds
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap.
ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning
from all of the work on plug-ins etc...
hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad.
enjoy the clip..i may have smoked too much at that the time i made it.
In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses?
Funny Orbits 3.zip (3,61 МиБ) скачан 497 раз(а).
#6 Опубликовано: 05.05.2023 16:29:48
Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it.
Click to enlarge
GTU-Ro-T.sm (397,19 КиБ) скачан 1404 раз(а).
#7 Опубликовано: 05.05.2023 17:16:54
... differently by doing what's wanted.
3D Plot.sm (61,83 КиБ) скачан 1350 раз(а).
3D Axes System XYZ User Explorer.sm (52,17 КиБ) скачан 1422 раз(а).
3D Axes System Parametric Explorer.sm (21,02 КиБ) скачан 1372 раз(а).
3D Solid cut by Surface.sm (72,29 КиБ) скачан 1395 раз(а).
#8 Опубликовано: 05.05.2023 21:04:08
...project 2D on 3D
Analemma [Project_Anim].sm (33,25 КиБ) скачан 1145 раз(а).
Analemma PROJECTION.sm (81,08 КиБ) скачан 1378 раз(а).
