vectorise() go to deep without first calculating the matrix product
vectorise() go to deep without first calculating the matrix product - I think it should multiply the matrices first and then apply the comparison per line. - Messaggi
#1 Pubblicato: 16/08/2019 12:18:08
manti7
manti7
0 apprezzamenti in 2 post.
I think the vectorize() command goes too deep in the example. Probably it takes the first row from the first matrix, then it probably tries to multiply it with the second vector. Then I get the error message: Number of rows and/or columns of matrices or vectors do not match.
Can somebody take a look at this, please?
matrix_nested_function.sm (11,57 KiB) scaricato 1182 volta(e).
#2 Pubblicato: 16/08/2019 14:05:19
CBG
CBG
78 apprezzamenti in 312 post.
Maybe this is a simple way to solve the problem
matrix_nested_function_CBG.sm (11,45 KiB) scaricato 1164 volta(e).
Carlos
#3 Pubblicato: 16/08/2019 14:07:39
Arie
Arie
94 apprezzamenti in 285 post.
Can eval input to f() as such
matrix_nested_function_alyles.sm (12 KiB) scaricato 1212 volta(e).
#4 Pubblicato: 16/08/2019 14:50:18
manti7
manti7
Thank you both for the quick answer! I didn't know there was an eval() function. I now understand that SMath resolves everything as low as possible and then calculates in one go. The use of eval() in the right place prevents this.
#5 Pubblicato: 16/08/2019 16:51:54
Maybe you complicate matters or not make it simpler from the truth table.
#6 Pubblicato: 16/08/2019 16:55:56
... some stuff Truth table
Utilities Matrix Truth Table [Locate row_col].sm (43,39 KiB) scaricato 1040 volta(e).
