1 pagine (6 elementi)
The problem with the function of the vector - Messaggi
Please help with the prZadanie 2.sm (9,86 KiB) scaricato 1457 volta(e).oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
Thanks for the help
File non trovato.
WrotePlease help with the prFile non trovato.oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12,66 KiB) scaricato 1452 volta(e).
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15,05 KiB) scaricato 1269 volta(e).
