Working Random Var [Compendium]
Working Random Var [Compendium] - Working Random Var [Compendium] - Messaggi
#1 Pubblicato: 01/01/2016 11:23:24
Enrich your projects with this starter.
Random Signum.sm (17,88 KiB) scaricato 1578 volta(e).
Random Stem Style.sm (15,54 KiB) scaricato 1522 volta(e).
Random more.sm (22,5 KiB) scaricato 1570 volta(e).
Randon Bin [Stem].sm (20,15 KiB) scaricato 1293 volta(e).
Randon Bin.sm (58,31 KiB) scaricato 1520 volta(e).
Randon Segment Circular Shapes.sm (38,25 KiB) scaricato 1585 volta(e).
Random UnitCircle.sm (40,22 KiB) scaricato 1516 volta(e).
Random [rnd(n)].sm (55,55 KiB) scaricato 1304 volta(e).
Random Fill Range PDF.sm (991,43 KiB) scaricato 1591 volta(e).
#2 Pubblicato: 01/01/2016 12:25:53
Gruppo: Moderator
Very nice examples Jean, as usual
The last file (where you presented the "fill" matrix - a large matrix in the gray area to the right) is an example where it might get you troubled. You can get red crossed box with Critical error, or at least the message "Object not set to an instance of an object". I think that you also mentioned this in some other examples. Presenting large matrices might be quite troublesome in SMath (although there are some plugins regarding this problem).
#3 Pubblicato: 02/01/2016 00:30:35
Radovan.
_______________________
That is true sometimes for unknown reason. And the worst is that it might work during
contruction, but zap on re-opening ! Other times it fails transmission. The "while"
looks solid in that respect. I tried many times 2000 points ... fine.
I'm used to these kind of problem from Mathcad. Sometimes the project is scrapped for
ever. We did the "Courant Surge" project for ITER [Cadarache], one of the data table
got lot and I have no more contact. It was not really a table, rather data:=
apparently less risky but evaporated. Crappy stuff gets transmitted as well.
Keep working hard 2016.
