[Custom Functions] Linear Interpolation
[Custom Functions] Linear Interpolation - Messaggi
#1 Pubblicato: 04/07/2019 17:18:01
Gruppo: Moderator
First of all I don't know if this method is supported, it would be very useful if not.
So if this is not a feature please forgive me because I considered as a bug.
The "InterBilinear" function gives wrong results if matrix is used for x or y value.
interpolation.sm (15,61 KiB) scaricato 1506 volta(e).
Davide Carpi 05/07/2019 04:41:00
#2 Pubblicato: 05/07/2019 00:34:26
Mathcad Bicubic can't be reproduced, even "if it could be"
would be useless whereas Smath does not have Matrix 3D plot [only 3 cols].
Your metric X,Y directions aren't correct. You can metric like center as well.
You can have surface plot, only... rotate the plot at will.
interpolation [Oterwise metric X, Y Directions].sm (33,32 KiB) scaricato 1321 volta(e).
#3 Pubblicato: 05/07/2019 01:19:17
Hi overlord. I prefer source code in a high level language, even it could be slowest.
interpolation bilinear source code.sm (26,59 KiB) scaricato 1495 volta(e).
#4 Pubblicato: 05/07/2019 01:41:17
You can have it otherwise from the X_Y surface plot.
interpolation [Oterwise metric X, Y Directions].sm (95,7 KiB) scaricato 1337 volta(e).
#5 Pubblicato: 05/07/2019 03:16:06
... you can create the matrix and the X, Y directions at will.
Then just interpolate ... Spline linterp has the virtue equivalent quadratic.
It would be mistake to cspline.
Bilinear SplineInterp [Construct USER].sm (12,86 KiB) scaricato 1248 volta(e).
#6 Pubblicato: 05/07/2019 04:39:22
Gruppo: Moderator
It is a bug, thank you! 4th and 5th argument type isn't checked, therefore (unintentionally) vector math applies.
#7 Pubblicato: 05/07/2019 09:15:23
Two things here:
1. The 4th and 5th arguments are presented in reverse order compared to Mathcad
2. The two dimension spline coding is from unknown source
...neither from either Smath [linterp, cinterp, ainterp]
...could be from erroneous quadratic source code.
As given in the attached: Spline(x,y,M) assumed = Mathcad Bicubic2D(x,y,M,vx,object)
At this point, you can spline/plot/rotate the surface as suggested before
Bilinear SplineInterp [Construct USER].sm (24,61 KiB) scaricato 1291 volta(e).
#8 Pubblicato: 05/07/2019 13:31:12
Two things here:
InterpBilinear(vx,vy,M,object,vector) ... does not collect"vector wise"
InterpBilinear(vx,vy,M,object,valueX) ... correct
That is the answer to the "bug",
