1 pagine (7 elementi)
Double Integration using ode solvers - Messaggi
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42,67 KiB) scaricato 1450 volta(e).
DoubleIntegralRK.pdf (219,12 KiB) scaricato 1015 volta(e).
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
WroteCan the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6,33 KiB) scaricato 1166 volta(e).
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60,58 KiB) scaricato 1448 volta(e).
GaussLegendreQuadrature.pdf (160,77 KiB) scaricato 1023 volta(e).
Yes.
DoubleIntegralSteelCat.sm (47,08 KiB) scaricato 1416 volta(e).
DoubleIntegralSteelCat.pdf (105,49 KiB) scaricato 837 volta(e).
Wrote...
Yes.
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28,98 KiB) scaricato 1195 volta(e).
WroteKeisan has longer Legendre than 64, but couldn't copy/paste ?
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25,63 KiB) scaricato 1383 volta(e).
DoubleIntegralJean.pdf (45,11 KiB) scaricato 934 volta(e).
WroteHi Jean. Yes, can copy and paste.
Thanks, Amigo !
