1 страниц (7 вхождений)
Double Integration using ode solvers - Сообщения
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42,67 КиБ) скачан 1444 раз(а).
DoubleIntegralRK.pdf (219,12 КиБ) скачан 1011 раз(а).
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
WroteCan the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6,33 КиБ) скачан 1158 раз(а).
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60,58 КиБ) скачан 1443 раз(а).
GaussLegendreQuadrature.pdf (160,77 КиБ) скачан 1018 раз(а).
Yes.
DoubleIntegralSteelCat.sm (47,08 КиБ) скачан 1411 раз(а).
DoubleIntegralSteelCat.pdf (105,49 КиБ) скачан 833 раз(а).
Wrote...
Yes.
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28,98 КиБ) скачан 1189 раз(а).
WroteKeisan has longer Legendre than 64, but couldn't copy/paste ?
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25,63 КиБ) скачан 1378 раз(а).
DoubleIntegralJean.pdf (45,11 КиБ) скачан 929 раз(а).
WroteHi Jean. Yes, can copy and paste.
Thanks, Amigo !
