How to display string element of the matrix in Smath Viewer?
How to display string element of the matrix in Smath Viewer? - Messaggi
#1 Pubblicato: 29/06/2018 08:53:06
Bartlomiej
Bartlomiej
0 apprezzamenti in 3 post.
I have a question if it's possible to display the string part of a matrix in *.exe file created from a Smath file?
Screenshot of issue
Tried the var2string function, but after changing the string value via exe file, it reads function argument name (a) instead of it's value.
Is there some kind of workaround for this issue?
#2 Pubblicato: 29/06/2018 10:37:31
Arie
Arie
94 apprezzamenti in 285 post.
It would help if you post the original .sm file.
I'm not exactly sure what you are trying to do. Are you trying to assign a value to a variable name defined in a?
If so you can do something like this: https://en.smath.info/forum/yaf_postsm36117_New-variable-programmatically--also--Solving-under-over-defined-system-of-linear-eqautions.aspx#post36117
As far as getting that dynamically created variable name to display on the left as an actual variable name, I'm not sure if that's possible.
#3 Pubblicato: 29/06/2018 10:42:57
Bartlomiej
Bartlomiej
In smath it's defined as:
a:="sample string"
a="sample string"
And if I change the string, sheet recalculates and shows a value as the new string. I wanted to achieve this functionality in smath viewer in exe file for creating additional info page on my docs, like project name and so on.
#4 Pubblicato: 29/06/2018 11:27:39
Arie
Arie
Make sure you hit enter/return key after entering value.
Edit: You may have found a bug. This kind of functionality works great with numeric values but not with strings. I've tried with different optimizations as well to no avail.
I'm not sure it's ever worked. I now SMath Viewer is still a work in progress so feel free to add bug entry.
#5 Pubblicato: 29/06/2018 14:33:35
CBG
CBG
78 apprezzamenti in 312 post.
Screenshot of issue
Hello Barmin
The function you are looking for was previously available in previous versions of smath, such as version 5737.
I do not know why they disabled it. Here I put an example in that version.
Test_string_5737.zip (359,64 KiB) scaricato 436 volta(e).
Carlos
#6 Pubblicato: 01/07/2018 13:56:27
Bartlomiej
Bartlomiej
Seems it's a bug then. Thanks for info.
#7 Pubblicato: 02/07/2018 11:07:17
Gruppo: Moderator
Can't reproduce
hallo.sm (2,75 KiB) scaricato 1174 volta(e).
hallo.zip (482,23 KiB) scaricato 419 volta(e).
#8 Pubblicato: 02/07/2018 11:11:51
Arie
Arie
Martin,
Once the Viewer is running try to change the value of Hallo and notice if it doesn't update in the second box.
#9 Pubblicato: 02/07/2018 22:58:56
CBG
CBG
#10 Pubblicato: 03/07/2018 04:58:49
Gruppo: Moderator
For me it works. Yet I have to press enter to forward the changes in the input box.
#11 Pubblicato: 03/07/2018 06:14:27
Gruppo: Moderator
For me it will change the numerical variable but not the string one (with return pressing, of course).
before
after
#12 Pubblicato: 05/03/2021 15:38:37
26 apprezzamenti in 155 post.
So what was the end result of this topic?
Why is the ability to modify text string entries disabled in the viewer?
#13 Pubblicato: 11/03/2021 21:34:26
This issue has now been resolved in the latest update.
#14 Pubblicato: 11/03/2021 22:55:14
CBG
CBG
Citazione
You are right, the text change in the variables still does not work.
Carlos
#15 Pubblicato: 11/03/2021 23:00:50
Please take a look at this topic. You will need the latest nightly build to have functionality.
#16 Pubblicato: 12/03/2021 14:17:50
CBG
CBG
I did a test with the latest version of Smath Studio and the Viewer and it does not work
Carlos
#17 Pubblicato: 12/03/2021 15:03:32
Carlos
Hi. Carlos it's right. I guess that there are an issue with the automatic update within the nightly build which seems to be now appVersion(4)="0.99.7739.40423"@# but previously I have appVersion(4)="0.99.7739.41xxx "@# or something like that.
#18 Pubblicato: 12/03/2021 22:08:51
Seems to be working just fine for me.
99.7739.40423_Test_exe.zip (571,28 KiB) scaricato 390 volta(e).
Good Luck!
#19 Pubblicato: 12/03/2021 22:12:22
I'm using 64bit Win10 Enterprise by the way. Maybe it matters?
Alvaro 12/03/2021 23:30:00
#20 Pubblicato: 12/03/2021 23:29:48
Me too, but 32 bits. I'm reinstall SMath and now works fine.
Thanks.
