function plot in range
function plot in range - Messaggi
#1 Pubblicato: 28/06/2021 18:50:59
Mateusz
Mateusz
0 apprezzamenti in 8 post.
Hi All,
Could you direct me how to plot the function for some range?
plot in range.sm (5,55 KiB) scaricato 1228 volta(e).
Best regards,
Astroneus
#2 Pubblicato: 28/06/2021 20:27:01
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
Speed graph
Phisic.sm (6,01 KiB) scaricato 1276 volta(e).
#3 Pubblicato: 28/06/2021 20:27:21
X_Y plots f(x,y)
#4 Pubblicato: 29/06/2021 06:21:43
Mateusz
Mateusz
It looks like that both solution are not what I want to get - especially the first one...
Is there any possibility simply to plot the chart where on Y-axis I simply put the a(t) and on x-axis time??? Because this what you proposed it looks tricky and there is necessity to control units. Therefore it is not intuitive ( at least for me ;P )
Please check the photo below made by ptc mathcad. This what I want to do, is to write the same as the function and plot it using the SMath.
Mateusz
#5 Pubblicato: 29/06/2021 08:53:31
Fridel Selitsky
Fridel Selitsky
In your conditions, only the speed and deceleration time are set.
Therefore a =const.Perhaps there are additional conditions
which you are not reporting.
#6 Pubblicato: 29/06/2021 09:27:41
#7 Pubblicato: 29/06/2021 09:46:14
Gruppo: Moderator
If that plot is what you need, here is your answer.
With function, dots for values and new axes grid {0.05, -2}.
plotting_range.sm (10,98 KiB) scaricato 1189 volta(e).
#8 Pubblicato: 29/06/2021 10:03:41
Mateusz
Mateusz
Hi Ber7,
This the acceleration during the breaking from 30km/h to zero in linear movement. Therefore in fact there is a(t)= v(t)/t. So: a_i= v_i / t_i and this is function where t is in some range, and i is the iterative change of time ie. the position of specific time. This what you wrote, is not the function of acceleration versus time.
Mateusz
#9 Pubblicato: 29/06/2021 10:05:47
Mateusz
Mateusz
@ Jean Giraud and @overload Thank you !
This is what I wanted to write in SMath!
Mateusz
#10 Pubblicato: 29/06/2021 10:44:11
Make your deceleration as you wish from a pre-selected vector 'a'.
#11 Pubblicato: 29/06/2021 11:17:05
This is what I wanted to write in SMath !
Differently convenient plot ...
plotting_range [1].sm (11,48 KiB) scaricato 1030 volta(e).
#12 Pubblicato: 29/06/2021 14:18:24
Hi. I agree with Ber7 that in absence of any other information the deceleration is constant. Physically that's means that the force of the breaks is constant too, which seems to be a good approximation, neglecting friction forces and some torque considerations about the wheels.
Hi Ber7,
Mateusz
Yes it is: a(t) = constant for t in the interval 0 .. 10 s.
#13 Pubblicato: 30/06/2021 08:24:19
@ Jean Giraud and @ overlord Thank you !
At this point, we can populate conveniently
then, pass Thiele continued fraction
and inspect for the first/2nd derivative.
I doubt you can do that in Mathcad/PTC
