1 pagine (2 elementi)
SMath Studio 0.98.5983 (19 May 2016) - Messaggi
SMath Studio 0.98.5983 available
Latest changes (against SMath Studio 0.98.5973)
- SS-2346: Handling of text strings to paste into the worksheet improved;
- Changing size of matrix inside the element of output matrix disabled in order to fix critical error happened in such cases;
- Added ability to select answer of math expression with manually set unit;
- SS-2318: Corrections made, see Preprocessing of symbolic data / functions' arguments for details;
- Cloud: Scrolling to top on every key down issue fixed.
Download
SMathStudioDesktop.0_98_5983.Setup.msi (Date: 19.05.2016. File size: 2.02MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_98_5983.Mono.tar.gz (Date: 19.05.2016. File size: 1.16MB) - last version of Mono distributive required! - Cloud version (all modern browsers supported):
SMath Studio in the Cloud (Date: 19.05.2016.)
6 utenti hanno apprezzato questo post
Davide Carpi 19/05/2016 19:51:00, Вячеслав Мезенцев 20/05/2016 01:45:00, NDTM Amarasekera 20/05/2016 09:05:00, Mike Kaganski 20/05/2016 10:17:00, sergio 21/05/2016 15:25:00, Tinu_ 22/05/2016 03:33:00
The attached sample doesn't work with the latest build 5983, but worked fine with all previous versions.
It indicates error x - not defined. Actually x is dummy, it was used as a place-holder for symbolic calculation.
cic3.sm (4,21 KiB) scaricato 1739 volta(e).
