[SS-3470] Derivative problem
[SS-3470] Derivative problem - Failing derivative function definition - Messaggi
#1 Pubblicato: 16/08/2017 06:45:17
Jan Claeys
Jan Claeys
2 apprezzamenti in 25 post.
Dear all,
I am currently struggling with a basic function extreme problem
NOK.sm (15 KiB) scaricato 1256 volta(e).
OK.sm (60,92 KiB) scaricato 1203 volta(e).
edit by mod: names of attachments are swapped, as mentioned below
In the first screenshot, the function derivative definition results in a warning message: "input string was not in a correct format"
In the last screenshot, I removed all parameters values that aren't related to the given formulas (not visible in the screenshot), and I get the right solution?! However, I don't see the root visually in the accompanying graph?
I thought it had something to do with the reservation of parameter "x", but this doesn't seem to be the case...
Thanks in advance for any feedback!
Kind regards from Belgium,
Jan
#2 Pubblicato: 16/08/2017 07:32:22
Gruppo: Moderator
could you please attach the worksheet?
#3 Pubblicato: 16/08/2017 07:46:09
Jan Claeys
Jan Claeys
Hello Martin,
Thank you for your fast reply, I just added the files...
#4 Pubblicato: 16/08/2017 08:41:19
The root(s) won't appear by magic ! You must instruct the plot.
Click left/right on the 2nd plot ... enable "Display input data"
Welcome to Smath Community, Jean
Maths Golden Ratio jmG.sm (21,35 KiB) scaricato 1219 volta(e).
#5 Pubblicato: 16/08/2017 08:49:37
Jan Claeys
Jan Claeys
Hello Jean,
What I meant was that the derivative graph doesn't cross the X-axis at x=3.29, this is where the original function P_c_hor(x) reaches it's maximum.
This is odd, since the root function indicates correctly a root at x=3.29 in the file NOK.sm (I switched the names the smath files, my mistake... ).
So my question remains: why does the solve function doesn't work in both attached files?
Kind regards,
Jan
#6 Pubblicato: 16/08/2017 09:56:42
Hey mon ami ! You have not attached any file .
Click on "Post reply" down the page.
You will see the icon line, click on the paper clip
"Insert an existing Attachment or upload a new file"
Browse for the file in your system, double click on the file name
You can add as many file as you wish [the limit is ~ 5 MB]
#7 Pubblicato: 16/08/2017 09:59:23
Jan Claeys
Jan Claeys
True, I added them afterwards to my first message ;-)
FYI: I switched the names of the files, my mistake...
You'll see what I mean if you compare the files.
I used the last beta version of smath.
#8 Pubblicato: 16/08/2017 12:18:09
It could probably be repaired by zapping the entire system.
Wait for Martin to check.
#9 Pubblicato: 16/08/2017 12:20:48
Jan Claeys
Jan Claeys
Ok, what do you mean with zapping? Debugging? Re-compiling the source code?
Thanks for your feedback!
#10 Pubblicato: 16/08/2017 13:18:46
... as it looks, the derivative as given is not accepted.
The mouse had problem digesting the elephant .
Done from infinitesimal analysis ... OK.
Maybe I open the wrong sheet ?
OK repaired.sm (63,49 KiB) scaricato 1233 volta(e).
#11 Pubblicato: 16/08/2017 18:23:05
Jan Claeys
Jan Claeys
Good evening Jean,
No, you edited the right sheet ;-) (nok is ok and vice versa, I was too fast when I changed the filenames... )
Thank you for the work you put into this, I really appreciate this!
As far as I can see, the problem seems to be (amongst others?) the use of units, since you removed every unit?
I am aware that good old Mathcad (when it still belonged to Mathsoft, PTC made a mess of it...) also struggled with this.
However, it stays unclear why my approach works in sheet "nok.sm" and not in "ok.sm", while it's 100% the same in both cases?!
There seems to be something wrong underneath the smath "boot"?
I will study the sheet more in detail (and put every value into SI) tomorrow at my work, thanks again!
Kind regards,
Jan
p.s. As a BD (bande dessinée) fan, your name reminded me of this legend (aka Moebius) ;-)
https://en.wikipedia.org/wiki/Jean_Giraud
#12 Pubblicato: 17/08/2017 14:46:41
Can't explain either. NO unit plots much smaller in magnitude and the function q(x) ends @ 3.5.
Infinitesimal analysis is a Lagrangian method that existed before "Symbolic engines".
Was effective for Excel to manage more advanced maths before Mathcad/Mathsoft... Maple.
It applies to 2nd derivative as well and integral. The 2nd derivative
starts producing noise [world is not perfect]. The Lagrangian methods extend
to point derivatives/integral ... very useful for point capture systems like
in Process Control & Instrumentation where have only values [accumulated values].
In the red, in the attached, I have isolated the Guilty ... Ah !
As it looks, with the unit system those "Guilty" may be smaller, thus less guilty.
Cheers, Jean
OK repaired.sm (144,28 KiB) scaricato 1258 volta(e).
#13 Pubblicato: 22/08/2017 12:46:57
Jan Claeys
Jan Claeys
Hello Jean,
I made a revised version of my original document today, based on your remarks. Luckily, I managed to keep the units "on board": by doing so the document is more readable for my colleagues.
Every value is correctly evaluated now: yes!
Thank you for the hint about the infinitesimal derivative, let's hope that SMath's next version will have a flawless standard derivative function, since the actual one doesn't seem to work...
Kind regards,
Jan
#14 Pubblicato: 22/08/2017 15:39:03
Jan,
Please attach the document ... there may be ways to doctor your derivative ?
In Smath, the derivative is strictly symbolic from the rules. Often, the rules
are chained to deeply + limits in numerical evaluation.
Glad you rescued the unit system. Attach just the working essentials.
#15 Pubblicato: 22/08/2017 20:21:09
Jan,
are chained to deeply limits in numerical evaluation.
Here is a good example the derivative operator fails
but rescued from the incremental derivative.
Maths Special Polylog Application.sm (21,19 KiB) scaricato 1202 volta(e).
#16 Pubblicato: 23/08/2017 06:39:26
Jan Claeys
Jan Claeys
Here the resulting file
Solution.sm (103,23 KiB) scaricato 1235 volta(e).
#17 Pubblicato: 23/08/2017 06:56:17
Gruppo: Moderator
I can run both the worksheets without errors (both in SS 0.98.6398 and latest beta)
#18 Pubblicato: 23/08/2017 10:05:56
Jan Claeys
Jan Claeys
Hello Davide,
I run the latest beta (build 6437), and f(2) on the last page of "ok.sm" doesn't result in an answer (the standard smath derivative function doesn't work)? I run Windows 7 Pro.
"nok.sm" does work, the reason for this is unclear because exactly the same formulas are used, however the graph doesn't show the correct shape of the derivative function.
It would be very strange if your configuration would be errorless?
There has to be a program mistake somewhere?
Kind regards,
Jan
#19 Pubblicato: 23/08/2017 10:49:12
* no units are used here to facilitate the "solve" command
In the definition of f(x) for the incremental derivative,
the units in num/den do match and f(x) is pure unitless,
just function of "x". The way you have it works fine.
The curiosity is that if we isolate/export the symbolic
expansion of f(x) ... the system fails ... damned puzzling !
Solution Isolate_Fails.sm (22,71 KiB) scaricato 1220 volta(e).
#20 Pubblicato: 23/08/2017 11:57:54
Gruppo: Moderator
It is strange indeed. Can you confirm that the error display on the uploaded file for you (download > open > error is shown; I mean, there were no issues while choosing the file to upload)
I run the same version as your, on Win7 home. It might be something related to some plugin (to check it you can rename your %APPDATA%\smath folder into something different, then you can load a new instance of SS studio and check if something is changed) or might be something else, I'll try to see if I can found a way to replicate it at least find the cause for that error message.
