Double pendulum model and animation
Double pendulum model and animation - Is the model correct? - Messaggi
#1 Pubblicato: 29/10/2025 09:15:19
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
Hi friends!
Now I am on the forum again!
Anime2.sm (55,59 KiB) scaricato 1043 volta(e).
But the model is not correct. See please Alvaro model!
Modificato 30/10/2025 19:22:14
#2 Pubblicato: 29/10/2025 10:45:45
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Using X-Y Plot
Anime2-xyplot.sm (57,84 KiB) scaricato 1078 volta(e).
sergio 29/10/2025 14:50:17, Ricardo_Herrera 03/01/2026 14:15:17
#3 Pubblicato: 29/10/2025 11:14:52
Valery Ochkov
Valery Ochkov
Thanks, Слава!
Modificato 29/10/2025 13:53:54
Alvaro 30/10/2025 07:04:33
#4 Pubblicato: 29/10/2025 13:56:31
Valery Ochkov
Valery Ochkov
Anime-x-y-plot.sm (18,24 KiB) scaricato 1002 volta(e).
And where here is a bug?
#5 Pubblicato: 29/10/2025 14:01:44
Gruppo: Moderator
Vector t must be defined below before the component.
The animation feature is still being developed when I have time for it.
Modificato 29/10/2025 14:05:45
Alvaro 30/10/2025 07:04:42
#6 Pubblicato: 29/10/2025 17:02:10
Valery Ochkov
Valery Ochkov
Слава, а когда этот новая версия плагина появилась?
#7 Pubblicato: 29/10/2025 18:19:29
Gruppo: Moderator
Citazione
В конце лета.
Modificato 29/10/2025 18:21:02
#8 Pubblicato: 30/10/2025 07:07:54
Hi. My approach to solving the double pendulum problem.
double_pendulum.sm (75,92 KiB) scaricato 1090 volta(e).
Вячеслав Мезенцев 30/10/2025 09:13:40, sergio 30/10/2025 12:18:26, Valery Ochkov 30/10/2025 07:45:32
#9 Pubblicato: 30/10/2025 13:32:00
Valery Ochkov
Valery Ochkov
Newton vs Lagrange
Pendulum-2.xmcd (119,12 KiB) scaricato 1069 volta(e).
#10 Pubblicato: 30/10/2025 18:31:11
Valery Ochkov
Valery Ochkov
My little edit
Alvaro 31/10/2025 04:29:45
#11 Pubblicato: 30/10/2025 19:33:11
Valery Ochkov
Valery Ochkov
Triple pendulum - see errors at the second haft of time interval.
Pendulum-3-for-SMath.xmcd (220,62 KiB) scaricato 1150 volta(e).
Modificato 30/10/2025 19:39:16
Alvaro 31/10/2025 05:05:16
#12 Pubblicato: 31/10/2025 05:03:31
Hi. Using pure SMath code to deduce the equations of motion from the Lagrangian, with the functions in this post: https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials.
double_pendulum_lagrangian.sm (174,64 KiB) scaricato 1032 volta(e).
double_pendulum_lagrangian.pdf (503,4 KiB) scaricato 781 volta(e).
Valery Ochkov 31/10/2025 07:37:56, sergio 31/10/2025 08:48:37
#13 Pubblicato: 31/10/2025 05:10:58
I no longer use Mathcad, except on rare occasions, when I rely on Mathcad version 11, which I consider the last decent version. So I can't see the triple pendulum file. And I suppose this is the situation for many SMath users who no longer have Mathcad readily available. But more than worrying about the conservation of energy, which seems to be a problem with the numerical method used, I'm more surprised to see how the future affects the past, since the animation shouldn't alter the trajectories already described by the particles as time passes.
This is my approach to the triple pendulum.
triple_pendulum_lagrangian.sm (135,01 KiB) scaricato 1006 volta(e).
triple_pendulum_lagrangian.pdf (248,09 KiB) scaricato 644 volta(e).
Modificato 31/10/2025 06:13:23
Valery Ochkov 31/10/2025 07:38:10, Вячеслав Мезенцев 31/10/2025 07:18:43
#14 Pubblicato: 31/10/2025 07:35:30
Valery Ochkov
Valery Ochkov
See pls pdf
Pendulum-3-for-SMath.pdf (589,25 KiB) scaricato 685 volta(e).
Modificato 31/10/2025 07:38:52
#15 Pubblicato: 31/10/2025 08:37:45
See pls pdf
With those values:
triple_pendulum_lagrangian.sm (159,26 KiB) scaricato 1035 volta(e).
Valery Ochkov 31/10/2025 10:39:04
#16 Pubblicato: 31/10/2025 10:38:47
Valery Ochkov
Valery Ochkov
For me too!
#17 Pubblicato: 01/11/2025 01:52:48
Valery Ochkov
Valery Ochkov
See pls pdf
With those values:
One my plot:
Change of three types of energy of a swinging pendulum on an elastic suspension - SE - the spring energy
Modificato 01/11/2025 01:55:02
#18 Pubblicato: 05/11/2025 07:01:02
Valery Ochkov
Valery Ochkov
Alvaro, hi!
Is it posibble to solve the single pendulun problem with Lagrangian and rkfixed but without the al_nleqsolve function?
Modificato 05/11/2025 08:29:15
#19 Pubblicato: 06/11/2025 04:03:01
Hi Valery. For the single pendulum you can get the lagrangian from the olf post about differentials ( https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials ) It's very simple and doesn't require much processing to use rkfixed.
For the double pendulum, you can use Newton-Raphson to solve the system within the function D. Here, a very simple version of the method is used.
double_pendulum_lagrangian-NR.sm (178,15 KiB) scaricato 1018 volta(e).
Something similar applies to the pendulum with a spring. Note that the Lagrange equations become somewhat complicated because I use the x,y coordinates to calculate the kinetic energy, and SMath cannot simplify trigonometric functions. However, if you use r, θ' (in green), the equations of motion are greatly simplified. But that breaks the principle that the program should do the calculations, not the user.
Valery Ochkov 06/11/2025 05:16:18
#20 Pubblicato: 06/11/2025 11:47:20
Valery Ochkov
Valery Ochkov
Hi Alvaro!
Can you create this simple sm-file with animation? Single pendulum!
Thanks!
