Beta: SMath Studio 0.99.6970 (31 January 2019) - Messaggi
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_99_6970.Mono.tar.gz (1,35 MiB) scaricato 2444 volta(e).
SMathStudioDesktop.0_99_6970.Setup.msi (2,23 MiB) scaricato 4858 volta(e).
Please note:
- There are some known bugs with Worksheet scrolling - will be addressed soon.
Wroteпри єкспорте в формат odt выдает ошибку
I'm unable to reproduce. Can you attach the file that cannot be saved as odt?
WroteWroteпри экспорте в формат odt выдает ошибку
Нужно указать больше информации об окружении: версия Windows, версия SMath Studio (+разрядность), версия используемого плагина (Data Exchange). Трудно без этой информации воспроизвести и решить проблему. Мне тоже не удалось её повторить.
WroteWroteпри єкспорте в формат odt выдает ошибку
Windows 7
SMath Studio Desktop 64 бит. ver. 0.99 сборка 6977
Data Exchange 1.1.6858.3747
WroteIt is possible that you don't have .NET 2.0/3.5 installed or enabled on your system (System.Web isn't available in .NET framework 4+ AFAIK). Please download the development tools plugin and then from "Insert > Development tools > System informations" paste the data here.
NET framework 4 is installed on the system
WroteNET framework 4 is installed on the system
In mine too; but what about previous versions?
CLR 4.0.30319.42000
installed versions:
v2.0.50727 2.0.50727.4927 SP2
v3.0 3.0.30729.4926 SP2
v3.5 3.5.30729.4926 SP1
v4
Client 4.7.03056
Full 4.7.03056
v4.0
Client 4.0.0.0
