SMath crashes on Linux Mint 22 - Messaggi
I have been using SMath Studio for several months, running as an AppImage on Linux Mint 21, without any problems. Recently, I upgraded to Linux Mint 22 and SMath Studio crashes when running. All errors are the following:
Citazione
eugenio@TARDIS:~ $ ./SMathStudioDesktop.1_1_8763.Mono.x86_64.ubuntu-22_04.glibc2.35.AppImage
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly:type: member null)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_generic_class_init(intptr)
at System.Drawing.Graphics.FromHdcInternal (System.IntPtr hdc) [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (System.IntPtr display_handle) [0x0007e] in:0
at System.Windows.Forms.XplatUIX11..ctor () [0x00077] in:0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x0001c] in:0
at System.Windows.Forms.XplatUI..cctor () [0x000e3] in:0
at System.Windows.Forms.Application.EnableVisualStyles () [0x00006] in:0
at .. (System.String[] ) [0x0002d] in <868b174b35bf46d7860f868d305a3a08>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly:type: member null)
Restoring environment...
Any idea how I can fix this? Thanks.
Error messages are referring to that library.
WroteCan you look if libgdiplus is installed?
Yes it is installed on my system
Maybe some libraries of new mint is not compatible with appimage.
https://smath.com/en-US/view/SMathStudio/download
WroteMono version does not work. I think that some libraries are not compatible with this SMath version...
Debian and debian based distros are always problematic with mono.
If you can make smath run with sudo, then there is a possible workaround.
Otherwise I'm sorry, it is debian (or ubuntu or mint)
