Matrix math - Newbie question
Matrix math - Newbie question - How do I multiply 2 elements in a variable length matrix ? - Messaggi
#1 Pubblicato: 07/06/2017 05:36:31
Peter J Francis
Peter J Francis
0 apprezzamenti in 18 post.
Hi All,
I'm trying to create an input table for a worksheet I'm working on.
It's probably a bit of a newbie question but I'm new to SMath (and matrices !) so any help would be appreciated.
I want to perform calculations on the data in matrix BODY.
I've done this in BODY2 as a workaround but I'd like to find a way of doing it so I don't have to edit BODY2 everytime I add or delete a row.
Any help / guidance would be appreciated
Peter
TableRegion_Test.sm (10,96 KiB) scaricato 1228 volta(e).
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#2 Pubblicato: 07/06/2017 07:13:32
Gruppo: Moderator
Hello Peter,
You can use a simple loop, like this:
TableRegion_Test.sm (10,15 KiB) scaricato 1241 volta(e).
Peter J Francis 07/06/2017 08:20:00
#3 Pubblicato: 07/06/2017 08:19:21
Peter J Francis
Peter J Francis
Thank you Davide
As I thought the answer was simple but I just couldn't see it.
I've been using Mathcad for a few years but have recently discovered SMath and am blown away by it.
Thanks again
Peter
#4 Pubblicato: 07/06/2017 11:30:28
Hello Peter !
Matrix maths is not same as "Matrix table".
I don't use much this feature for collecting data, but can demonstrate how to fill.
By same token, the attached "matrix Treasury might help in real "Matrix maths".
Welcome to Smath Community
TableRegion_Test jmG.sm (22,12 KiB) scaricato 1231 volta(e).
Utilities Matrix Treasury Copy.sm (336,08 KiB) scaricato 1289 volta(e).
Peter J Francis 09/06/2017 06:42:00
