1 pagine (8 elementi)
Differentiation operator does not evaluate symbolically - Translate a differential operator from SMath to Maxima - Messaggi
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (9,34 KiB) scaricato 1152 volta(e).
Thanks in advance,
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (13,39 KiB) scaricato 1160 volta(e).
WroteHello,
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
frapuano 31/05/2020 04:51:00
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (17,82 KiB) scaricato 1168 volta(e).
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
WroteThank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
WroteI am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
If Mathcad Prime does not solve those attached ... Oh !
ODE Symbolic 4_Flies.sm (130,62 KiB) scaricato 1186 volta(e).
ODE Symbolic Bernoulli.sm (11,38 KiB) scaricato 1207 volta(e).
ODE_Laplace 1rst [Type 2].sm (22,68 KiB) scaricato 962 volta(e).
ODE Symbolic Verhulst [Logistic].sm (25,55 KiB) scaricato 1028 volta(e).
ODE Symbolic Lambert.sm (21,81 KiB) scaricato 1200 volta(e).
ODE_Laplace 1rst [Type 1].sm (24,7 KiB) scaricato 978 volta(e).
ODE_Laplace 2nd [Type 3].sm (34,62 KiB) scaricato 1038 volta(e).
ODE Symbolic Eiffel.sm (21,45 KiB) scaricato 1159 volta(e).
