Standard templates?
Standard templates? - Is it possible to create (and re-use) a template in smath? - Messaggi
#1 Pubblicato: 03/08/2020 13:51:52
Richyo
Richyo
0 apprezzamenti in 2 post.
Hi everyone, I’ve been using smath for about a year now (since mathcad became completely rubbish!) and use it for standard engineering calcs (mechanical and structural mainly).
I’m freelance so tend to perform calcs for many clients and have not yet found a way to create a standard calculation sheet template.
For example, whenever I start a new project I’d like a header or something on the front page to display my company name and a few other fields for title, project number, that sort of thing. Possibly even have a margin down one side for referencing standards or notes. Something like the sci calc sheets that are online would be great!
Does anyone know of a way to do this or is there a plug-in somewhere?
Any advice would be much appreciated.
Thanks!
Richard
#2 Pubblicato: 03/08/2020 14:19:01
127 apprezzamenti in 342 post.
you can use:
Insert -> Header and Footer
Insert -> Field
Also you can see this post by Alvaro (Razonar)
https://en.smath.com/forum/yaf_postst13853_Automatic-numbering-sections-book.aspx
#3 Pubblicato: 03/08/2020 14:29:06
Few ways of presenting professional works. Any use ?
Template.sm (15,57 KiB) scaricato 1907 volta(e).
Template Background Multiple.sm (14,22 KiB) scaricato 1820 volta(e).
Template Cartouche.sm (19,42 KiB) scaricato 1735 volta(e).
Template Background Construct.sm (47,88 KiB) scaricato 1814 volta(e).
Template Cartouche Venturi.sm (21,78 KiB) scaricato 1687 volta(e).
Template Else Source.sm (3,94 KiB) scaricato 1734 volta(e).
Template Cartouche CREATE.sm (53,17 KiB) scaricato 1660 volta(e).
Template Cartouche Saved.sm (4,53 KiB) scaricato 1630 volta(e).
Template Guy.sm (2,65 KiB) scaricato 1735 volta(e).
Template Cartouche Example.sm (34,49 KiB) scaricato 1655 volta(e).
Template YellowCorn.sm (3,31 KiB) scaricato 1688 volta(e).
Template Cartouche Geoff.sm (31,7 KiB) scaricato 1649 volta(e).
Template Cartouche Otherwise.sm (74,54 KiB) scaricato 1667 volta(e).
#4 Pubblicato: 02/09/2020 09:48:17
Richyo
Richyo
Hi, apologies for the delayed response! The templates linked below are great - thank you for providing these.
I've looked at a few and haven't quite found what I need yet but I'll work on it. Once I have something I'll post it here so everyone else can use it (if they want to!)
Thanks again,
Richard
#5 Pubblicato: 02/09/2020 13:15:51
Visit them all for the next month !
Foot note standard/references best go in collapsed above document.
#6 Pubblicato: 05/01/2022 15:08:29
Claudio Andre
Claudio Andre
0 apprezzamenti in 3 post.
Create an empty file with your template settings and set it as readonly, when you try to save Smath will ask you a new name.
