1 pagine (11 elementi)
Wrong display of output units - Messaggi
I've just started using this software and I think that it's great. However, I came across an issue that may be a bug. Here's my input:
a := 0,1 m
b := 0,05 m
L := 1 m
M := 1000 Nm
τ_max := (2*M)/(π*a*(b^2)) =
Now in the last line I want to change units to MPa. But when I do it (by writing MPa in the right placeholder), I get the following result:
No matter what I try, I can't get rid of this part that I highlighted in red. I want to have just MPa on the right side. Is that a bug or am I doing something wrong ?
a := 0,1 m
b := 0,05 m
L := 1 m
M := 1000 Nm
Perhaps you are using 'Nm instead of 'N*'m
If you want you can define your own torque unit 'Nm:'N*'m before the calculations, otherwise you have to multiply the force unit fot the length unit
EngMath 30/05/2021 09:05:00
Problem solved, thank you very much. I had to type 'N*'m as you say because 'Nm wasn't recognized properly.
Wrote... you can make the unit system silent, i.e: inactive
This is close to recommending pencil and paper.
WroteThis is close to recommending pencil and paper.
Pretty close Martin, that's ± what QA sanity check does.
The mV/I temperature converter reads mV ... then displays °C.
In parallel to the black box mV/I, read mV, interpolate wrt NBS [now NIST].
