solve() by Maple Plugin gives an "arctan() function not defined" error
solve() by Maple Plugin gives an "arctan() function not defined" error - solve() by Maple Plugin gives an "arctan() function not defined" error - Messaggi
#1 Pubblicato: 29/05/2013 12:24:16
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
I found this behavior working with Maple plugin:
I think that it would be easily fixed by uni
Thanks in advance!
Oscar
#2 Pubblicato: 29/05/2013 12:53:16
Gruppo: Moderator
@uni
I think that you can use directly:
ExpressionString = ( new Regex( @"\batan\(" ) ).Replace( ExpressionString, Functions.Arctg + @"(" );
ExpressionString = ( new Regex( @"\barctg\(" ) ).Replace( ExpressionString, Functions.Arctg + @"(" );
using the Functions.* you don't need to write the right SMath function name.
best regards,
w3b5urf3r
#3 Pubblicato: 29/05/2013 21:17:53
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Oscar, could you attach the file and the log (mvr5.txt)? As for me your example works fine.
@w3b5urf3r
Thanks, I forgot about that.
#4 Pubblicato: 30/05/2013 17:58:33
Oscar Campo
Oscar Campo
Gruppo: Moderator
Here the files.
Thanks in advance!
Oscar
#5 Pubblicato: 31/05/2013 10:19:11
Gruppo: Moderator
Here the files.
Thanks in advance!
Oscar
Fixed and updated. Try now.
