How to make bode plot in Smath Studio
How to make bode plot in Smath Studio - Messaggi
#1 Pubblicato: 22/12/2024 16:30:31
Cornel
Cornel
2 apprezzamenti in 78 post.
How to make bode plot in Smath Studio like below in Mathcad prime?
Only x-axis is in logarithmic
#2 Pubblicato: 22/12/2024 19:55:45
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Hi Cornel,
This can help you:
Please see this post
Change H(s) for your own
francesco rapuano 22/12/2024 20:50:00
#3 Pubblicato: 23/12/2024 02:17:04
Cornel
Cornel
Hi Cornel,
This can help you:
bodeplot_smath.sm (71,46 KiB) scaricato 1903 volta(e).
But how can I plot these 2?
#4 Pubblicato: 23/12/2024 03:11:44
Oscar Campo
Oscar Campo
Gruppo: Moderator
Cornel,
The arguments for a plot must be a function or a couple of column vectors.
I your case you can use in your plot the vectors you are calculated and use as input for the graph:
Best,
Oscar
#5 Pubblicato: 23/12/2024 03:22:50
Cornel
Cornel
Cornel,
Best,
Oscar
But I want to plot augment(freq, 20*log()) and augment(freq, arg()), which does not work..this îs the problem
#6 Pubblicato: 23/12/2024 03:30:00
Oscar Campo
Oscar Campo
Gruppo: Moderator
augment(freq, arg()) and augment(freq, 20*log()) really works... only must adjust the axis... your yaxis is set 0~100 and your data appear in the 0~(-100) axis
#7 Pubblicato: 25/12/2024 01:23:30
Cornel
Cornel
I'm starting to dislike Smath's problems/bug and that is not working continuously fine...2 days ago I could see the Zedgraph settings, and now when I try to enter in the settings of Zedgraph, Smath crashes...
#8 Pubblicato: 25/12/2024 03:40:21
Gruppo: Moderator
I'm starting to dislike Smath's problems/bug and that is not working continuously fine...[/attach]
Now I am done with being polite.
If you don't like this much, use another program.
Alvaro 25/12/2024 13:35:00
#9 Pubblicato: 25/12/2024 03:57:24
Cornel
Cornel
Aren't you annoyed by the fact that SMath doesn't continously work well?
I'm trying to give SMath a try because I like that it has better symbolic calculation capabilities than Mathcad Prime, but I also see SMath's shortcomings or things that are easy to see in Mathcad Prime but not in SMath...
#10 Pubblicato: 25/12/2024 04:11:48
Gruppo: Moderator
Actually, no I am not. Because SMath works as it is intended.
Near everything you can do with mathcad v15, you can do with smath, in some way.
Just not with exact workflow. You only have to put some effort on SMath.
These two programs are similar but not same.
Base program has some inferiority in some areas, but with plugins it can be quite comprehensive.
I can say what is your problem, you invested so much for other programs.
We use SMath for 10+ years, we know how it works. You don't.
You need to learn smath way, not mathcad way.
In addition, smath symbolic operations are much primitive.
That's why we use maple or maxima plugin for that purpose.
#11 Pubblicato: 25/12/2024 05:01:56
Cornel
Cornel
Let's see then how things will evolve in futute. I hope to learn SMath way, but for sure I will need your/this comunity members suport.
#12 Pubblicato: 25/12/2024 07:52:26
Gruppo: Moderator
Let's see then how things will evolve in future. I hope to learn SMath way, but for sure I will need your/this community members support.
Well, this is the good part.
If someone knows it, you will always get your questions answered.
And usually, one of hyper-intelligent member of this forum knows the way.
We have a lot of doctors and professors here.
